DCS2 computer
From GammaSphere DAQ
Revision as of 00:04, January 22, 2026 by Ttang (talk | contribs)
This is analysis computer for GammaSphere.
Network IP
192.168.203.56 or dcs2.onenet
Note to the Users
  • Use your personal ANL account to login.
  • Don't save data in your home
  • Use the network drive to save data.
  • Your network home is located at /nethome/anl/<your ANL account name>
  • Network file system is located at /dgsdata
  • ROOT 6.36.04 is available at /opt/root or /usr/local/cern/root_v6.36.04. Need to source the thisroot.sh.
  • KSHELL avalible at /opt/kshell
  • For any python packages for your own usage, please use virtual environment.
  • Please let Ryan to know if you want any packages or software to be installed
Common account for GammaSphere analysis
  • This account in managed by Ryan. Ryan will delete anything I don't understand.
Software
Software/Code Info. Location
ROOT 6.36.04 ROOT 6.36.04 /opt/root or /usr/local/cern/root_v6.36.04
KShell Shell model calculation /opt/kshell
Specification
This is an AMD Ryzen Threadripper 9980X 64-core (128-threads) with 256 GB RAM. It also equip with NVIDIA RTX PRO Blackwell GPU.
Component Specification
Motherboard ASUS Pro WS TRX50-SAGE WIFI
RAM 4 x 64 GB DDR5-5600 MT/s ECC RDIMM (256 GB Total)
CPU AMD Ryzen Threadripper 9980X (64-Core, 128-Threads)
GPU NVIDIA RTX PRO 2000 Blackwell (16 GB GDDR7, 4352 CUDA Cores)
Disk Samsung SSD 990 PRO 1TB (OS disk)
Network 3 x 10GB/s port
Storage and Disk
Disk Capacity Type Note
/ 1 TB NVMe OS disk. Don't save data in here
Network Drive
The physics file server is mounted on
Location Mount point Old aliases READ/Write by dcsu
fs1.onenet:/mnt/vol2/atlasdata/dgs dgsdata/fs1/vol2 /dk/fs1/dgs Read
fs2.onenet:/mnt/vol2/atlasdata/dgs /dgsdata/fs2/vol2 Read
fs2.onenet:/mnt/vol3/atlasdata/dgs /dgsdata/fs2/vol3 /dk/fs2b/dgs Read
fs2.onenet:/mnt/vol4/atlasdata/dgs /dgsdata/fs2/vol4 Read
fs2.onenet:/mnt/vol5/atlasdata/dgs /dgsdata/fs2/vol5 Read/Write
