Firmware documentation
"User manual" type documentation is provided here. Newer versions may be present on the DGS Subversion repository as updating of this page is a manual process.
- File:DGS trigger system firmware user guide.pdf was uploaded by JTA on 20180501.
- File:MYRIAD Module Specification.pdf was uploaded by JTA on 20180501.
- File:ANL Firmware for LBL Digitizer.pdf was uploaded by JTA on 20180501.
- Scientists should first read File:Non-Expert ANL Firmware - ANL version.pdf as this provides a shorter summary of features and is easier to digest.
- If you want to know more after the Non-Expert document then read File:ANL Digitizer Firmware for Experts.pdf for further details about how the firmware works.
- These two documents are newer than File:ANL Firmware for LBL Digitizer.pdf and present firmware changes that have occurred since this document was written.
- File:20160418 trig command link.pdf was uploaded by JTA on 20180501.
- File:CPLD sum logic.pdf was uploaded by JTA on 20180501.
- File:Interfacing Digital Gammasphere with other detectors and systems.pdf was uploaded by JTA on 20180501.
- File:TripletPulseNotesTake2.pdf was uploaded by JTA on 20180501. This document demonstrates using the Digitizer Tester to show the effects of integration time and readout length settings on complex waveforms.
Go back to Digital Gammasphere Upgrade Project
