EDM Scripts
From GammaSphere DAQ
Revision as of 15:48, March 21, 2023 by Amujahid (talk | contribs)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
Scripts are used for different setup purposes and can easily cause problems. They should only be touched if absolutely necessary and shouldn't be used alone. Below are options for the different controls you can run from scripts. This image is not clickable.
  • Lock All Setup manipulates all the links to connect all the boards together for the trigger system.
Go back to DGS Commander EDM Screens
