EDM Temperature Monitor
From GammaSphere DAQ
Revision as of 18:42, March 17, 2023 by Amujahid (talk | contribs)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
The temperature monitor shows the temperatures in each detector. The detectors, each having a unique number ID from 1 - 110, are grouped together by the "hemisphere" of Gammasphere they're in, where the northern hemisphere has the odd numbered detectors, and the southern hemisphere has the even numbered detectors. The Ge needs to be maintained at a certain temperature at all times, and if it surpasses a certain temperature, the detector becomes in need of repair.
Go back to DGS Commander EDM Screens
Go back to LN Control Options
