Analysis codes
From GammaSphere DAQ
Revision as of 19:09, June 12, 2018 by Tlauritsen (talk | contribs)
GEBSort_nogeb
GEBSort_nogeb is the program that can analyze data from DGS, DFMA and GRETINA.
For DGS data, enable bin_dgs in the GEBSort.chat file. To find the PZ values to use, sort some data from a 207Bi source. Then extract the clean ehi spectra in .spe format with this command
  .x get_ecln.cc
Now run:
  dgs_pz 350 100 dgs_pz.cal
where 350 100 are the M and K values you find in the runxx.save file. Specify the values in 10 nsec units.
Now sort again (resort) using the new pz values that were extracted above. Extract the new clean ehi spectra as
  .x get_ecln.cc
and run the calibration program
  dgs_ecal dgs_ehi.cal 207Bi
you can also use "88Y", "60Co" for the source.
