Analysis codes
From GammaSphere DAQ
Revision as of 19:01, June 12, 2018 by Tlauritsen (talk | contribs)
We have two kinds of data analysis codes, GTSort receives UDP packed from the IOCs and can give some impression on whether signals are coming in or not, but to look for coincidences it is necessary to
  • merge (GTMerge3) the data from the different IOCs
  • use the DGSSort root sorter on the merged data
GEBSort_nogeb
GEBSort_nogeb is the program that can analyze data from DGS, DFMA and GRETINA.
For DGS data, enable bin_dgs in the GEBSort.chat file. To find the PZ values to use sort data from a 207Bi source. Then extract the clean ehi spectra in .spe format with this command
  .x get_ecln.cc
then run:
  dgs_pz 350 100 dgs_pz.cal
where 350 100 are the M and K values you find in the runxx.save file. Specify the values in 10 nsec units.
Now sort again (resort) using the new pz values that were extracted above. Extract the new clean ehi spectra as
  .x get_ecln.cc
and run the calibration program
  dgs_ecal dgs_ehi.cal 207Bi
(old) GTMerge3/DGSSort
To checout the software, compile and run
  • cd whereYouWantToWork
  • make
modify test.sh with information about where your data is, etc
  • ./test.sh
  • root -l (.x bar.cc, ...)
(old) GTSort
The official version of GTSort is at
but it is not always up to date. Shaoufei is the point man for GTSort
