Purpose
This page will be updated whenever someone responsible enters new data about hardware being moved, hardware being checked for firmware revision, or otherwise located. The purpose is to try and have some kind of historical knowledge of what boards are where and what firmware is in what board.
MyRIADs
| Module # |
Where Last Seen |
When |
Firmware |
Base Address |
Notes
| 6 |
F116 Test Stand |
20180425 |
Example |
Example |
No labels; 13PC003A; DIP switches set for 0x5500 address; missing some test points
| 3 |
F116 Test Stand |
20180425 |
Example |
Example |
Labeled GRETINA/0x5500; 13PC003; has clock mux power filter.
| 5 |
F116 Test Stand |
20180425 |
Example |
Example |
no label; 13PC003A; DIPswitch addr = 0x5500; missing some test points
| 1 |
F116 Test Stand |
20180425 |
Example |
Example |
Labeled x550000; missing C66; resistor, not inductor, power filter mod;
| Example |
Example |
Example |
Example |
Example |
Example
| Example |
Example |
Example |
Example |
Example |
Example
| Example |
Example |
Example |
Example |
Example |
Example
Triggers
| Module # |
Where Last Seen |
When |
Firmware |
Base Address |
Notes
Example |
Example |
Example |
Example |
Example |
Example
| Example |
Example |
Example |
Example |
Example |
Example
Digitizers
| Module # |
Where Last Seen |
When |
Firmware |
Base Address |
Notes
Example |
Example |
Example |
Example |
Example |
Example
| Example |
Example |
Example |
Example |
Example |
Example
Digitizer Testers
| Module # |
Where Last Seen |
When |
Firmware |
Base Address |
Notes
Example |
Example |
Example |
Example |
Example |
Example
| Example |
Example |
Example |
Example |
Example |
Example
Slope boxes
| Module # |
Where Last Seen |
When |
Firmware |
Base Address |
Notes
Example |
Example |
Example |
Example |
Example |
Example
| Example |
Example |
Example |
Example |
Example |
Example
Trigger Cable Plant Sets
| Module # |
Where Last Seen |
When |
Firmware |
Base Address |
Notes
Example |
Example |
Example |
Example |
Example |
Example
| Example |
Example |
Example |
Example |
Example |
Example
Fiber Adapters
| Module # |
Where Last Seen |
When |
Firmware |
Base Address |
Notes
Example |
Example |
Example |
Example |
Example |
Example
| Example |
Example |
Example |
Example |
Example |
Example
MVME5500s
| Module # |
Where Last Seen |
When |
Firmware |
Base Address |
Notes
Example |
Example |
Example |
Example |
Example |
Example
| Example |
Example |
Example |
Example |
Example |
Example
DGS (short) digitizer cables
| Module # |
Where Last Seen |
When |
Firmware |
Base Address |
Notes
Example |
Example |
Example |
Example |
Example |
Example
| Example |
Example |
Example |
Example |
Example |
Example
