Analog Gammasphere
From GammaSphere DAQ
Revision as of 18:43, March 5, 2014 by Tlauritsen (talk | contribs)
setting up the analog GS DAQ from scratch
from a linux box type
 telnet gsts1 2009
That will give you a console window for the analog DAQ system. In here, type 'crtl x' that will reboot the VME processor. After It gets up, type
 </home/sga2/cur/startup_sga2.cm
 sgainit
put a USB disk in the the USB docking station on the machine you want to store your data on. It should automount as something like /media/20140304. To use the disk it needs to be exported. Do that as
 gsexportfs 20140304
notice that you should not specify '/media'
Now log into dgs1 as dgs and
 cd /home/sga2/cur/config
 cp a cmd file to c1.cmd
 edit c1.cmd for your purpose
specify the directory to store the data as something like
 datadir gslinux1 /media/abcd/user/tltmp
here is an example of a c1.cmd file that works on the disk named maounted on gslinx1
# cmd file created by "savepars" command
# __ on SAT MAY 11 03:04:24 2013
datadir gslinux1 /media/20140304/user/tltmp
# note -- you should specify a new dir if
#         you have just rebooted
newexp myexp myexp
# note -- you may want to increment the run number below
newrun myexp 5
getimewin 3950 4030
bgotimewin 1950 2030
feradelay 8
setrecversion 1
tgecomoff 4095
tbgocomoff 0
sendto gslinux1
sendfrac 100
setmode +GC_MODE
setmode -TIME_VETO
setmode +HC_SUPPRESS
setmode +WRITE_GE_TIME
setmode -WRITE_GE_FULL
setmode -WRITE_BGO
setmode -WRITE_ALL_GE
setmode -WRITE_ALL_BGO
setmode +RF_TIMING
fileheader on
checkebevlen 1
ratealarm off
badcesdump 0
You can use this file as a template if you wish.
You should now be able to start the DAQ and see something like this:
 sga2: start
 acquisition started
 sga2: EB CES switch detected, but there was no overflow flag in CES=1, usi1=0!
  1083(8) ev/s; CES 50/50%; no ehi 0.5%; alarm off @ 03/05 12:30
  5968(20) ev/s; CES 54/46%; no ehi 0.5%; alarm off @ 03/05 12:30
  5740(20) ev/s; CES 49/51%; no ehi 0.5%; alarm off @ 03/05 12:31
  5132(18) ev/s; CES 49/51%; no ehi 0.5%; alarm off @ 03/05 12:31
to stop the DAQ and take your data away
On the GAQ console, type
 stop
on the machine where you have mounted your data disk, type
 gsunexportfs 20140304
using the datdisk name example from above. This ensures that we unexport the file so that we can eject the disk using the usinf the standard linux utility:
 locate icon of disk on monitor
 click 'safely remove Drive'
 confirm that icon coes away
 type 'df' to further confirm disk is unmounted
then you can turn your disk off and remove it.
online data monitoring
TBD
VXI processsor boots
The VXI processors have dgs6 as their boot host. This is a scientific linux 6.4 blade computer sitting in the dgs rack. There is a pull out keyboard and monitor for dgs6 in the rack.
The boot parameters for the vxi processors are documented below
  boot device          : ln
  processor number     : 0
  host name            : dgs6 listed
  file name            : /vxboot/kernels/boot/niCpu030-t/vxWorks
  inet on ethernet (e) : 192.168.203.170:ffffff00 listed
  inet on backplane (b):
  host inet (h)        : 192.168.203.184
  gateway inet (g)     :
  user (u)             : vxprod
  ftp password (pw) (blank = use rsh):
  flags (f)            : 0x0
  target name (tn)     :
  startup script (s)   : /vxboot/daq/boot/resm/startup.lrc1
  other (o)            :
  boot device          : ln
  host name            : dgs6
  inet on ethernet (e) : 192.168.203.171:ffffff00
  gateway inet (g)     :
  user (u)             : vxprod
  flags (f)            : 0x0
  target name (tn)     :
  startup script (s)   : /vxboot/daq/boot/resm/startup.lrc2
  other (o)            :
  boot device          : ln
  host name            : dgs6
  inet on ethernet (e) : 192.168.203.172:ffffff00
  gateway inet (g)     :
  user (u)             : vxprod
  flags (f)            : 0x0
  target name (tn)     :
  startup script (s)   : /vxboot/daq/boot/resm/startup.lrc3
  other (o)            :
  boot device          : ln
  host name            : dgs6
  inet on ethernet (e) : 192.168.203.173:ffffff00
  gateway inet (g)     :
  user (u)             : vxprod
  flags (f)            : 0x0
  target name (tn)     :
  startup script (s)   : /vxboot/daq/boot/resm/startup.lrc4
  other (o)            :
  boot device          : ln
  host name            : dgs6
  inet on ethernet (e) : 192.168.203.174:ffffff00
  gateway inet (g)     :
  user (u)             : vxprod
  flags (f)            : 0x0
  target name (tn)     :
  startup script (s)   : /vxboot/daq/boot/resm/startup.lrc5
  other (o)            :
  boot device          : ln
  host name            : dgs6
  inet on ethernet (e) : 192.168.203.175:ffffff00
  gateway inet (g)     :
  user (u)             : vxprod
  flags (f)            : 0x0
  target name (tn)     :
  startup script (s)   : /vxboot/daq/boot/resm/startup.lrc6
  other (o)            :
  boot device          : ln
  host name            : dgs6
  inet on ethernet (e) : 192.168.203.176:ffffff00
  gateway inet (g)     :
  user (u)             : vxprod
  flags (f)            : 0x0
  target name (tn)     : vxi7
  startup script (s)   : /vxboot/daq/boot/resm/startup.mrc
  other (o)            :
History: The hosting of the vxi processors was originally done by the 'shack' sun computer (which is still alive in the data room), then the hosting was taken over by the 'shack2' Dell linux box (a regular tower). We switched to the dgs6 rackmounted blade machine to save space in the shack.
