Run procedures
From GammaSphere DAQ
start DAQ
There are 3 controls associated with Run Control on the main page of either GUI
  • Start/Stop - this is self explanatory. Pushing to start begins taking data.
  • NoSave/Save - If set to Save, IOC buffers fill with data. You must attach a receiver to each digitizer IOC or the system may crash horribly once the buffers fill up.
  • Copy/Sort - In Sort mode, the data out of the IOC is time ordered according to the time stamp. You should always be in the Sort mode
To start the DGS and DFMA systems do the following:
  • on the DGS side, find the window where the DGS data is stored. There will be a start.sh script there. Start the receivers up by typing
 start.sh <runNo>
where <runNo> is the run number you want. A bunch of windows should show up, one for each receiver/IOC pair
  • On the DFMA side, find the where the DFMA data is stored. There will be a start.sh script there. Start the receivers up by typing
 start.sh <runNo>
where <runNo> is the run number you want, the same as what you used on the DGS side. A bunch of windows should show up, one for each receiver/IOC pair in the FMA setup
stop DAQ
write your instructions here
Changing gain in Phill's signal box
Linking two or more systems
syncing two systems
For DGS
  • Goto trig0 window.
  • Turn off SYNC U - listed under LRU Control
  • Make sure receive/send power is on for L & U
Note: If SYNC U is turned off - an Impeartive sync by DGS will reset the master clock on DFMA.
For DFMA
  • Goto Trig0 Window
  • Under Misc Control - turn on both undefined buttons
  • Pull up diagnotsitc window on trig0.
  • Set Clrk Source to LINK
  • Set Nim1 and Nim2 out on master trigger module FMA
Note: Clock Source cannot be set to LINK in GUI. Set address 0x8D0 in slot 0 to set 1 for trigger modules. This needs to be fixed in Driver by Tim.
receivers
cables
changing FPGA Firmware code
