Run procedures
From GammaSphere DAQ
Revision as of 00:59, January 7, 2013 by Tlauritsen (talk | contribs)
start DAQ
this is how you start the daq,
  • first you do this
  • then you do that
  • and then it crashes
  • and then you call Mike
Good instructions makes things easy, that is why we have none.
stop DAQ
write your instructions here
Changing gain in Phill's signal box
Linking two or more systems
syncing two systems
For DGS
  • Goto trig0 window.
  • Turn off SYNC U - listed under LRU Control
  • Make sure receive/send power is on for L & U
Note: If SYNC U is turned off - an Impeartive sync by DGS will reset the master clock on DFMA.
For DFMA
  • Goto Trig0 Window
  • Under Misc Control - turn on both undefined buttons
  • Pull up diagnotsitc window on trig0.
  • Set Clrk Source to LINK
  • Set Nim1 and Nim2 out on master trigger module FMA
Note: Clock Source cannot be set to LINK in GUI. Set address 0x8D0 in slot 0 to set 1 for trigger modules. This needs to be fixed in Driver by Tim.
receivers
cables
changing FPGA code
