Run procedures
From GammaSphere DAQ
Revision as of 21:33, January 3, 2013 by Zhu (talk | contribs)
start DAQ
this is how you start the daq, this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,
  • first you do this
  • then you do that
  • and then it crashes
  • and then you call Mike
Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none.
stop DAQ
this is how you stop the DAQ, this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,
gtsort
Don't do it! Don't do it! Don't do it! Don't do it!
linking two or more systems
write your instructions here
syncing two systems
Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none.
receivers
cables
changing FPGA code
