Run procedures
From GammaSphere DAQ
Revision as of 20:56, January 3, 2013 by Tlauritsen (talk | contribs) (start DAQ)
start DAQ
this is how you start the daq, this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,
  • first you do this
  • then you do that
  • and then it crashes
Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none. Good instructions makes things easy, that is why we have none.
stop DAQ
this is how you stop the DAQ, this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,
linking two or more systems
write your instructions here
syncing two systems
receivers
cables
changing FPGA code
