Run procedures
From GammaSphere DAQ
start DAQ
this is how you start the daq, this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,this is how you start the daq,
stop DAQ
this is how you stop the DAQ, this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,this is how you stop the DAQ,
linking two or more systems
write your instructions here
syncing two systems
receivers
cables
changing FPGA code
