Coprocucts
From GREET.net Help
Revision as of 18:46, March 21, 2012 by Ddieffenthaler (talk | contribs)
Allocation
Calculations
Parameters
  • Outvalue=Outa*Outcost = Value associated with the main output amount, after the losses. Outcost = {energy value, market value, mass, volume}
  • Coprvalue=Copra*Coprcost = Value associated with the co-product output amount. Coprcost = {energy value, market value, mass, volume}
  • ee = Energy and Emissions associated to that co product ( in Joules and Grams per unit of Output for the current process )
  • inputs = Energy and Emissions for all the inputs of the current process ( in Joules and Grams per unit of Output for the current process )
Calculations
For each allocation method it will be the same idea :
  • We convert the amount given for the co product into a quantity of energy, mass, market value or volume depending on the allocation method chosen.
  • We grab the amount after losses of the main output
  • We calculate the allocation ratio which will be :
r=1OutvalueOutvalue+Coprvalue
  • We calculate the energy and emissions associated to that co product :
ee=rinputs
Note : Outvalue and Coprvalue are in the same unit, they can be both in Joules, Grams, Cubic Meter or Dollar depending of the allocation method chosen.
Displacement
Calculations
Parameters
  • MixEEmpm = conventional material mix energy and emissions, which are the necessary energy and emissions associated to the production of that material for the specified purpose for this specific mix.
  • Smpm = the share of the conventional material purpose mix displaced.
Calculations
  • For each conventional material mix defined in the displacement ratios we grab the mix energy and emissions. We also grab at the same time the conventional material share.
  • We add to the co product energy and emissions the amount displaced, by each conventional material displaced :
ee=ee+MixEEmpmSmpm
XML Example
This example is extracted from the process Dry Mill Ethanol Production (US Industry Average). It shows a coproduct which is calculated as a displacement. But if the user wants to change the method and calculate it with the allocation method, the different options which will be shown to the user are also defined.
<coproduct ref="116" method="displacement" amount="[dgs_params!A3];0;True;pounds">
  <allocation value="energy" >
    <option>energy</option>
    <option>market</option>
    <option>mass</option>
  </allocation>
  <conventional_products >
    <product ref="75" purpose="stationary" mix="0" ratio="[composite_displacement_ratios!B3];0;True;percentage"/>
    <product ref="117" purpose="stationary" mix="0" ratio="[composite_displacement_ratios!C3];0;True;percentage"/>
    <product ref="91" purpose="stationary" mix="0" ratio="[composite_displacement_ratios!D3];0;True;percentage"/>
  </conventional_products>
</coproduct>
Common Calculations
Parameters
  • Scopr = share of the coproduct
Calculations
At the end of the calculation process for one of this co products we are doing a last operation which is multiplying the ee by a share. This share can be used to define many co products and assign them shares. So the last operation will be : ee=ee*Scopr
Internal Links
