Monitor Values
From GREET.net Help
Revision as of 23:05, January 23, 2012 by Aanjum (talk | contribs) (Internal Links)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
Monitor Values Overview
Menus to monitor and view the values
Greet.net allows user to monitor a value in the property Display grid in Pump to Wheels setup. Monitoring values in Greet is a straight forward process. However, before going into the details of monitoring values it may be beneficial to review how data is calculated. In Greet results are viewed after a calculation run has been completed. After altering different parameters a user must recalculate data in order to get new results. The data monitoring features allows the user to track how a value changes after each calculation run.
How to Monitor Values
To monitor a value, Right click the value in the property display and select "Monitor this Value". The changed value is saved after each calculation run. To see all the Monitored values, Select Results -> Monitoring Results or by pressing F10.
Internal Links
