Monitor Values
Monitor Values Overview
Greet.net allows user to monitor a value in the property Display grid in Pump to Wheels setup. Monitoring values in Greet is a straight forward process. However, before going into the details of monitoring values it may be beneficial to review how data is calculated. In Greet results are viewed after a calculation run has been completed. After altering different parameters a user must recalculate data in order to get new results. The data monitoring features allows the user to track how a value changes after each calculation run.
How to Monitor Values
Monitoring values in Greet is a straight forward process. However, before going into the details of monitoring values it may be beneficial to review how data is calculated. In Greet data is viewed after a calculation run has been completed. After altering different parameters a user must recalculate data in order to get new results. The data monitoring features allows the user to track how a value changes after each calculation run. To see all the Monitored values, Select Results -> Monitoring Results or by pressing F10.
