Monitor Values
Monitor Values Overview
Greet.net allows user to monitor a value in the property Display grid in Pump to Wheels setup. Monitoring values in Greet is a straight forward process. However, before going into the details of monitoring values it may be beneficial to review how data is calculated. In Greet results are viewed after a calculation run has been completed. After altering different parameters a user must recalculate data in order to get new results. The data monitoring features allows the user to track how a value changes after each calculation run.
To monitor a value, Right click the value in the property display and select "Monitor this Value". The changed value is saved after each calculation run. The stochastic studies cannot be done yet, but this is a manual version of it. To see all the Monitored values, Select Results -> Monitoring Results or by pressing F10.
How to Monitor Values
Monitoring values in Greet is a straight forward process. However, before going into the details of monitoring values it may be beneficial to review how data is calculated. In Greet data is viewed after a calculation run has been completed. After altering different parameters a user must recalculate data in order to get new results. The data monitoring features allows the user to track how a value changes after each calculation run. To see all the Monitored values, Select Results -> Monitoring Results or by pressing F10.
