HPC/Sharing Files
Introduction
Sharing files on Carbon
When you collaborate with other users on a common project on Carbon you will naturally wish to share files among you. There are several ways to do this, largely distinguished by how often and for how long sharing is needed.
Transferring files to or from Carbon
See HPC/Network Access/SSH Tunnel Setup on Linux and MacOS#File transfer.
Group types
Proposal groups
Typically, a group and associated sharing directory are created automatically for each CNM proposal that has more than one user. Access those directories under one of the following names:
/home/SHARE/cnm12345 ~cnm12345
- Of course, replace 12345 by the relevant proposal that you are a member of.
Named project groups
Leveraging a named project group is a convenient way for users to share files over periods longer than a single proposal will be active (12 to 18 months).
Contact the Service Desk to request a project group and directory. Send the following information:
- A brief description of the project subject matter,
- One or more proposed group names that are:
- short (at most 8 characters),
- descriptive (can be a software name or project acronym)
- distinctive.
- A user list of initial members; later additions or removals will be easy to make.
Location
- A new Unix group will be created and populated by the relevant users as described above. Group members will receive an email with instructions that new group memberships will be "picked up" by the system upon the next login.
- A group directory will be created at:
/home/SHARE/groupname /home/SHARE/cnm12345
- On shell command lines and in scripts, the directories can also be accessed as:
~groupname ~cnm12345
- This "
" shortcut form is typically not interpreted in application programs (written in Fortran, C, Python, etc.). To best use shared directories with such applications, best practices are:
- Issue a
cd
shell command before running the program, or - In the calling shell or job script, set and export environment variables if supported by the application. They often are of the form
FOO_HOME
,FOO_ROOT
, orFOO_LIBDIR
. Carbon's "module" scripts for applications automatically do this. - Use relative path names, such as
dir/under/here
or../otherdir/other_subdir/
- Use absolute paths only when other directories are needed as well.
- Issue a
Managing permissions
Carbon's /home/SHARE
directories are configured as follows:
- The shared directory will be mutually readable and writable among group members, and will not be accessible by other users.
- Files newly created in a shared directory will automatically become group-shared (by inheriting group membership).
- Unfortunately, files moved into a shared directory do not automatically become group-shared because files being moved retain their original typically user-private user and group ownerships.
To share directories and files that are not accessible by group members, the file owner – or an administrator – must run the following:
- To make files writeable by group members:
chgrp groupname shared_file ... chmod g+rw shared_file ...
- To make a directory and all files thereunder (-R) group-writeable, which includes the ability to delete files:
chgrp -R groupname shared_dir_name chmod -R g+rwX shared_dir_name
Lean more about chmod, chown, and chgrp.
Advanced permission handling
Directories under /home/SHARE
are typically created administratively
with the setgid bit active,
which will cause newly created files and directories to inherit the shared group of the parent, and thus become shared as well.
But this inheritance does not apply to existing directories that have been moved here.
To share moved directories, run the commands above, then switch on group inheritance as follows:
find shared_dir_name -type d -print0 | xargs -0 chmod -v g+s
The first part of this pipeline can be run alone to simply show a list of all directories (-type d
), like so:
find shared_dir_name -type d find shared_dir_name -type d -ls
The full command as shown earlier produces that list in a robust manner (using NULL-terminated strings of names), then uses xargs(1) to run chmod(1) to activate the setgid bit on these directories (but not files).
Alternatively, instead of moving files into a proposal-shared directory, copy them first, then remove the source:
cp -R --preserve=timestamps source_dir ~cnm123456/ rm -r source_dir
Sharing in your own directories
You can give access to some of your directories in your respective $HOME or $SANDBOX by opening permissions.
- This option is typically useful for one-way sharing.
- For bidirectional sharing, you will need to grant world-write permissions, which is not recommended for files in your own directory space.
- You will likely need to repeatedly open permissions (
chmod
) for additional files that are placed there.
You as the owner can arrange this on your own as follows:
chmod a+x $HOME/ mkdir $HOME/share # populate .. chmod -R a+rX $HOME/share
- This will yield read ("r") and execute ("X") permissions for all users ("a"), meaning users can browse directories, and read and execute already executable files there.
- You may have to repeat the last step after you add files in the shared directory.
Direct your fellow users as follows:
cd /home/owner/share ls cp -p ....
The first cd is crucial to have your collaborator step into a sharing directory you designated instead of stepping in from your home directory. Other users are not usually able to simply rummage around your home directory with "ls" – it is up to you to show them a specific directory they can browse.
If you have particularly large files, replace $HOME
and /home
by $SANDBOX
and /sandbox
, respectively.
Using a /tmp directory
You can drop files into the general-use /tmp directory of a login node and set permissions as needed. This way of sharing is:
- suitable for one-off exchanges,
- typically fairly loose with permissions,
- resides on only one host,
- world-write is not recommended,
- likely to need chmod whenever more files are placed.
To share files under /tmp, do the following:
mkdir /tmp/foo # populate .. chmod -R a+rX /tmp/foo
