HPC/Applications/gaussian
From CNM Wiki
Introduction
Gaussian is an electronic structure program used by chemists, chemical engineers, biochemists, physicists and others for research in established and emerging areas of chemical interest.
Starting from the basic laws of quantum mechanics, Gaussian predicts the energies, molecular structures, and vibrational frequencies of molecular systems, along with numerous molecular properties derived from these basic computation types. It can be used to study molecules and reactions under a wide range of conditions, including both stable species and compounds which are difficult or impossible to observe experimentally such as short-lived intermediates and transition structures. This article introduces several of its new and enhanced features.
User access
Argonne's license agreement with Gaussian, Inc. restricts the use of Gaussian applications to Argonne employees.
Versions
The Gaussian versions on Carbon are 64-bit versions with full support for shared memory and Linda parallelization.
module -l avail gaussian
gaussian/09/09.D.01.x86_64-3           2015/12/02 17:25:23
gaussian/16/16-A.03-1                  2017/10/16 12:42:41
gaussian/16/16-A.03-2                  2017/10/16 12:35:29
gaussian/16/16-B.01-1                  2019/05/28 16:56:37
gaussian/16/16-C.01-1                  2019/08/20 10:03:31
The last version is the default at present, obtained by the (recommended) version-free module command:
module load gaussian
Job script
  • Inspect the job script template (after having loaded the module) as follows:
$GAUSSIAN_HOME/g16.job
Usage
Copy the template script and use it in one of two ways:
  • edit for each job as needed, or
  • adapt the script for basic needs of several jobs, and individualize it by the PBS job name.
The job name can be up to 15 characters long and should not contain unusual characters. Set it, along with your project name and the walltime limit on the qsub command line:
qsub -N foo [-l walltime=hhh:mm:ss]  g16.job
Operation
Upon job execution, the script reads your Gaussian input file and modifies it use under PBS on Carbon, as follows:
  • Link0-commands for parallelization are inserted automatically.
Tool for parsing Gaussian output
Much of the output from Gaussian is available in plaintext format in the log file. Many users write grep-like utilities on their own to extract such information.
I wrote one as well, and it is available alongside each gaussian module. The tool grew out of my own needs. Contact me if you encounter a bug, need additional functionality, or simply find it useful.
Example
gauss-parse *out
# d3h_dec.out
# Energies (H)
#it E (H)                   dE (eV)     dE/step (eV)
 1  -1421.2018695          0.00000000     0.00000000
 2  -1421.28679099        -2.31083263    -2.31083263
 3  -1421.38689495        -5.03480153    -2.72396890
# job end
Help
For documentation, run:
gauss-parse --help
gauss-parse --man
To give an idea of scope, here is the output upon --help:
Usage:
    gauss-parse [options] [gaussian-output-file ...]
Options:
    --energy    Output energies (default).
    --spectrum  Output eigenvalues.
    --diis      Print DIIS errors.
    --geometry  Output geometries (into separate files unless --join is given).
    --charge    Output Mulliken charges. When --Spin is used, output spin densities instead.
    --force     Output forces.
    --freq      Output frequencies.
    --archive   Expand archive entry [plaintext, with line breaks]
    --last      Print output for last frame only.
    For --energy, --geometry, or --force modes only:
    --pick frame_number
                Output only the given frame number (counted from 1).
    --basename name
                Select file name for output (an embedded %d will be increased for each input files)
   --join      Output geometry into a multi-frame xyz-format file.
   --input     Pick input orientation
   --std       Pick standard orientation
   --Spin      Use spin occupancy as scalar quantity (default: charge)
   --units unit
               Convert energy and force units (default: no conversion).
Notes on Linda
Gaussian is parallelized in two complementary ways:
Incomplete node use
Gaussian/Linda may decide not to use the entirety of the nodes made available to it by the preprocess stage in the PBS job file. This section describes how to determine when this is the case and what to do about it.
Consider the following input:
%mem=20mw
#p MP2/6-311G(2df,p) force symm=loose MaxDisk=250000000 test
This being run in the job file through the preprocessor produces the input that Gaussian will see, inserting the node names allocated by PBS:
%NProcShared=32
%LindaWorkers=n456,n457
%mem=20mw
Gaussian will echo its input line by line in its log file:
Entering Gaussian System, Link 0=/opt/apps/gaussian/16-C.01-1/libexec/avx2/g16/g16
Initial command:
/opt/apps/gaussian/16-C.01-1/libexec/avx2/g16/l1.exe "/tmp/3174927.sched5.carboncluster/Gau-38174.inp" -scrdir="/tmp/3174927.sched5.carboncluster/"
Default linda workers: n532,n518
Default is to use  16 SMP processors on each worker.
Entering Link 1 = /opt/apps/gaussian/16-C.01-1/libexec/avx2/g16/l1.exe PID=     38178.
Copyright (c) 1988-2019, Gaussian, Inc.  All Rights Reserved.
This is part of the Gaussian(R) 16 program.  It is based on
the Gaussian(R) 09 system (copyright 2009, Gaussian, Inc.),
the Gaussian(R) 03 system (copyright 2003, Gaussian, Inc.),
Cite this work as:
Gaussian 16, Revision C.01,
Gaussian 16:  ES64L-G16RevC.01  3-Jul-2019
               22-Jan-2025
%mem=1GB
%chk=d3h_dec.chk
SetLPE:    new flags="-opt 'Tsnet.Node.lindarsharg: ssh'  -nodelist 'n532.carboncluster n518.carboncluster' -env GAUSS_MDEF=134217728 -env GAUSS_EXEDIR="/opt/apps/gaussian/16-C.01-1/libexec/avx2/g16:/opt/apps/gaussian/16-C.01-1/lib/bsd""
Will use up to    2 processors via Linda.
#P ub3lyp/6-31g(d) opt freq scf=nosymm test
The last line will be specific to your Gaussian route section.
  • I highly recommend to use the #P (= "profuse") option to better track progress through Gaussian's link stages.
  • The term processors is used inconsistently here. For shared memory, it means cores, but for Linda it means nodes.
  • You can track the use of Linda by:
grep exel file.out
  • Gaussian may decide to not use Linda after all. A note like this will appear in the log file:
PrsmSu:  requested number of processors reduced to:   6 ShMem   1 Linda.
In this case, decide wether it would be better to resubmit the job than to leave nodes allocated by PBS idle. It is possible that Gaussian's decision is different for different Linda links. Only the longest-running link would be relevant for you to evaluate resubmission.
Error messages
When running jobs on more than one node (i.e., using Linda), you may see messages like these in a job's error stream:
eval server 0 on n456.carboncluster has dropped it's connection.
subprocess pid = 11505 has exited. status = 0x0000, id = 0, state = 17. command was /opt/..../linda.../opteron …
died after signing in successfully
These messages are not indicative of a problem. They indicate that the Linda work in a Gaussian link is finished, and that Gaussian is continuing with a new link.
  • The environment variable GAUSS_FLAGS (as set in the "gaussian" modulefile) is now configured to include the flag -v, to better trace Linda operations on worker nodes. Additional lines like the following will show up in a job's error stream:
ntsnet: using executable file /opt/apps/gaussian/16-C.01-1/libexec/avx2/g16/l302.exel
ntsnet: trying to schedule 1 worker
ntsnet: scheduled a total of 1 worker
ntsnet: starting master process on n456.carboncluster
ntsnet: starting 1 worker on n456.carboncluster
This example shows how one link within a job of #PBS -l nodes=2:ppn=16 gets executed under Linda.
