Nanoprobe Scanning Quick Reference/dude
Jump to navigation
Jump to search
Get the latest version at home
Go to https://hub.docker.com/r/danielzt12/dude
check out the latest version, and specify that when executing the docker run command.
Load data
File -> Open, point to the mda folder and click OPEN.
If you are using dude to look at data other than those acquired with the Eiger detector, change that under Settings -> Detector.
Main interface
[1] right mouse click on the canvas or drag while clicked, show the corresponding detector images. Also work for 1D scans.
[2] when doing step [1], the motor positions and detector values are also updated , under P0 (Point 0).
[3] left mouse click on the canvas updates the position under P1 (Point 1), and calculates the distance between P1 and P0. Does not work for 1D scans.
[4] disable Auto
