Nanoprobe Scanning Quick Reference
Back to X-Ray Microscopy
Chamber overview
<gallery mode="packed-hover">
The Nanoprobe Instrument (NPI) consists of a Focusing Optics Module which holds a Fresnel zone plate that is integrated with a central beam stop. This optic focuses through a differentially adjustable Order Sorting Aperture (OSA) so that the primary unfocused beam is blocked either by the central sotp or the OSA - this OSA stage is also mounted on the FOM allowing the combination to be moved simultaneously. The combination of these two elements focuses the beam onto the Sample Module that provides translational and rotational control of the sample position. Laser interferometry is used to track the X/Y position of both the optic and sample stages relative to a common reference frame, allowing the user to scan the fine position of the optic differentially locked in to the sample position which continuously corrects uncontrolled positional drift over the scan.
Coarse scanning
Image for coarse scanning here
Fine scanning
Image for fine scanning here
Focusing
Image for focusing here
