HPC/Applications/lammps/Package GPU
Package GPU
- Provides multi-threaded versions of most pair styles, all dihedral styles and a few fixes in LAMMPS; for the full list:
- In your browser, open http://lammps.sandia.gov/doc/Section_commands.html#comm
- Search for the string /cuda.
- Supports one physical GPU per LAMMPS MPI process (CPU core).
- Multiple MPI processes (CPU cores) can share a single GPU, and in many cases it will be more efficient to run this way.
Usage
- Use the command
package gpu Ngpunear the beginning of your LAMMPS control script. Since all Carbon GPU nodes have just one GPU per node, the Ngpu argument must be 1. - Do one of the following:
- Append /gpu to the style name (e.g. pair_style lj/cut/gpu).
- Use the suffix gpu command.
- On the command line, use the -suffix gpu switch.
- In the job file or qsub command line, request a GPU
#PBS -l nodes=...:gpus=1(referring to the number of GPUs per node). - Call the
lmp_mpi-gpubinary.
Input file examples
package gpu force 0 0 1.0 package gpu force 0 0 0.75 package gpu force/neigh 0 0 1.0 package gpu force/neigh 0 1 -1.0
… pair_style lj/charmm/coul/long/gpu 8.0 10.0
Alternatively, use the following command line options:
lmp_mpi-gpu -sf gpu -pk gpu 1 -in file.in > file.out
Job file example
#PBS -l nodes=...:gpus=1 … mpirun … lmp_mpi-gpu -in infile
