HPC/Applications/python
< HPC | Applications
Python variants
Interpreter-only releases from the Python Software Foundation
- Contains
- The Python interpreter only, from the python.org sources.
- Module nomenclature
python/pyMajor.pyMinor/compilerName-compMajor.compMinor/pyMajor.pyMinor.pyPatch-moduleBuild
Python interpreters and packages as bundled with the OS
- Contains
- The Python interpreter that comes with the operating system is required for many system-provided and add-on packages.
python-osname/pyMajor.pyMinor/compilerName-compMajor.compMinor/pyMajor.pyMinor.pyPatch- Notes
- Such a module normally does not need to be loaded. It is included here for visibility in the module system, and as a base for (usually older) modules which provide Python packages outside of Conda or Pip. Such packages are often tied to the version of the Python interpreter under which they were installed.
Conda-based Python suites
- Contains
- Wide-ranging Python-based software suites, rather than specific HPC applications, with the package selection as distributed by the vendor.
python-distributor/pyMajor.pyMinor/distMajor/distributor_defined_version[…]-moduleBuild
The suites typically contain:
- A Python interpreter as a base.
- The conda/pip package management systems.
- Idle – Python Integrated DeveLopment Environment
- A rich set of Python-native packages, extensions, and add-on executables, usually including
- iPython and juPyter – Interactive computation system
- Cython – Compiler for a superset of Python and C/C++
- Underlying libraries and supporting binaries, e.g.:
- Tcl – Interpreter for the Tool Command Language
- BLAS/LAPACK – Linear algebra libraries
- MPI – Runtime environment for parallel applications using Message Passing Interface, providing the
mpirunormpiexeccommands, plus related binaries and libraries.
Caveat: An MPI Runtime within a Python suite makes parallel computing easily accessible under Python, but this means a "mere python module" can clash with other MPI implementations used on Carbon.
Avoid loading both a Python suite and an MPI implementation at the same time, especially in your dot-files. Doing so may lead to non-obvious failures with either the bundled parallel Python applications or (worse) unrelated compiled applications on Carbon.
Custom Conda environments
- Contains
- Conda environments derived from a vendor-distributed Conda suite, with the package selection customized for Carbon.
python-env-distributor/pyMajor.pyMinor/distMajor/pyVersion[…]-moduleBuild
Possible extension for alternative package selections:
python-env-distributor-purpose/pyMajor.pyMinor/distMajor/pyVersion[…]-moduleBuild
