HPC/Applications/python
From CNM Wiki
Revision as of 22:58, January 9, 2018 by Stern (talk | contribs)
Python variants
Interpreter-only releases from the Python Software Foundation
Releases of just a Python interpreter from the python.org sources:
python/pyMajor.pyMinor/compilerName-compMajor.compMinor/pyMajor.pyMinor.pyPatch-moduleBuild
Interpreter releases bundled with the OS
The Python interpreter that comes with the operating system is required for many system-provided and add-on packages. It normally does not need to be loaded as a module. It is included here for visibility in the module system, and as a base for (usually older) modules which provide Python packages outside of Conda or Pip. These packages often are tied to the interpreter version under which they were installed.
python-osname/pyMajor.pyMinor/compilerName-compMajor.compMinor/pyMajor.pyMinor.pyPatch
Conda-based Python suites
These packages are not specific applications but rather wide-ranging software suites which typically contain:
  • a Python interpreter
  • the conda/pip package management systems,
  • a rich set of Python-native packages and add-on executables as selected by the distributor,
  • all underlying libraries like LAPACK and possibly even MPI.
    • Idle – Python Integrated DeveLopment Environment
    • Tcl – Interpreter for the Tool Command Language
    • MPI – Runtime environment for parallel applications using Message Passing Interface, providing the mpirun or mpiexec commands, plus related binaries and libraries.
Caveat: An MPI Runtime within a Python subsystem makes parallel computing easily accessible under Python, but this means a "mere python module" can clash with other MPI implementations on Carbon.
Avoid loading both a Python suite and an MPI implementation at the same time, especially in your dot-files. Doing so may lead to non-obvious failures with either the bundled parallel Python applications or (worse) unrelated compiled applications on Carbon.
python-distributor/pyMajor.pyMinor/distMajor/distributor_defined_version[…]-moduleBuild
Conda environments
These packages are conda environments, derived from one of the conda suites , with package selection customized for Carbon:
python-env-distributor/pyMajor.pyMinor/distMajor/pyVersion[…]-moduleBuild
# or?
python-env-distributor-Carbon/pyMajor.pyMinor/distMajor/pyVersion[…]-moduleBuild
# Possible extension for alternative package selections:
python-env-distributor-purpose/pyMajor.pyMinor/distMajor/pyVersion[…]-moduleBuild
