Sandbox/Migration example
< Sandbox
Here is an example of what you might see:
$ modules-migrate This application will help you adapt your environment-modules customizations to Carbon's 2016 module naming scheme. Your module commands in .bashrc will be deactivated (commented out) and instead placed into two similar files .modules-el5-legacy and .modules-el6, for use by different operating system releases. This helper application will modify your files in a fairly simplistic manner. You will have an opportunity to manually review and refine the edits. Continue? [Y/n] y ---------------------------------------------------------------------- diff of changes from .bashrc: ---------------------------------------------------------------------- 8,10c8,10 < module load vasp5 < module load g09/D.01.x86_64-2 < module load GaussView --- > # module load vasp5 > # module load g09/D.01.x86_64-2 > # module load GaussView Accept changes in .bashrc? [Y/n] y Putting in place ... `.bashrc.tentative' -> `.bashrc' Opening text editor for .modules-el5-legacy.tentative .modules-el6.tentative ... Continue? [Y/n] y
A text editor will open (session output omitted here).
- Review and adapt as needed.
- Save each file.
- Quit the editor.
Example output continues:
==> .modules-el5-legacy.tentative <==
# Carbon initialization for modules in scheme 1, used on CentOS-5.
# To use scheme 2 instead, create .modules-el5.
# Initially extracted from .bashrc by modules-migrate .
# This file is read by module profile/user, in TCL syntax.
module load vasp5
# vim:syntax=tcl:
==> .modules-el6.tentative <==
# Carbon initialization for modules in scheme 2, used on CentOS-6.
# Symlink this file to .modules-el5 to load the same set on older nodes.
module load vasp5
module load gaussian/09/D.01.x86_64-2
module load gaussview
# vim:syntax=tcl:
View (v)
Edit (e)
Test (t)
Cancel (c)
Install and quit (q)
Enter selection: q
Installing files ...
`.modules-el5-legacy.tentative' -> `.modules-el5-legacy'
`.modules-el6.tentative' -> `.modules-el6'
Done.
