Sandbox/Migration example
From CNM Wiki
Revision as of 20:32, April 28, 2016 by Stern (talk | contribs)
Here is an example of what you might see:
$ modules-migrate
This application will help you adapt your environment-modules customizations to
Carbon's naming scheme 2 (introduced in 2016).
Your module commands will be _removed_ from .bashrc and instead placed into two similar
files .modules-1 and .modules-el6, for use by different operating system releases.
NOTE: The file text manipulation done here is fairly basic. You will have
opportunity to review and edit the results.
Continue? [Y/n] y
diff of changes from .bashrc:
19,21c19,21
< module load vasp5
< module load g09/D.01.x86_64-2
< module load GaussView
> #	module load vasp5
> #	module load g09/D.01.x86_64-2
> #	module load GaussView
Accept changes in .bashrc? [Y/n] y
Putting in place ...
`.bashrc.tentative' -> `.bashrc'
Opening text editor for .modules-1.tentative .modules-el6.tentative ...
Continue? [Y/n] y
A text editor will open (session output omitted here).
  • Review and adapt as needed.
  • Save each file.
  • Quit the editor.
Example output continues:
Review: "module" lines in new files:
==> .modules-1.tentative <==
# Carbon modules initialization for v1-style module names, used on CentOS-5.
# To stop using v1-style modules, remove this file.
# Initially extracted from .bashrc by modules-migrate .
# This file is in TCL syntax.
module load vasp5
# vim:syntax=tcl:
==> .modules-el6.tentative <==
# Carbon modules initialization for v2-style module names, used on CentOS-6.
# Also used on CentOS-5 if .modules-1 does not exist.
module load vasp5
module load gaussian/09/D.01.x86_64-2
module load gaussview
# vim:syntax=tcl:
Accept changes (a), Edit (e), or Quit (q)? a
Renaming files ...
`.modules-1.tentative' -> `.modules-1'
`.modules-el6.tentative' -> `.modules-el6'
Done.
