HPC/Module naming scheme 2016
Configuration files used
You have files: .bashrc and … |
Remark | CentOS-5 uses: | CentOS-6 uses: | |||
files | module names | files | module names | |||
– | – | Starting situation. | .bashrc only | version 1 | .bashrc only | version 2 |
– | .modules-2 | Switch over, recommended. | .modules-2 and .bashrc | version 2 | .modules-2 and .bashrc | |
.modules-1 | – | Only recommended during transition. | .modules-1 and .bashrc | version 1 | .bashrc only | |
.modules-1 | .modules-2 | For advanced users. | .modules-1 and .bashrc | version 1 | .modules-2 and .bashrc |
New-style module names
You may need to adapt the module names that you placed in your shell startup and job files to the new more hierarchical scheme. For most modules, with exceptions show below, the leading name component (the part before any "/") is the same in the old and new naming schemes. What always differs are the name parts after the first slash.
Name change rules
- To use the latest or automatically selected version of a package, remove version numbers from old-style module names of the form
packagename/version
, leaving onlypackagename
. This is the recommended approach, as you will automatically benefit from future updates and maintenance builds. - To insist on a specific version for a package in new style names:
- Inspect the available flavors and versions (some older modules were not migrated):
module avail packagename
- Choose the new-style name up to the desired specificity. You may leave out trailing name or directory parts.
- For instance, instead of
vasp5/5.3/openmpi-1.4/intel/5.3.3p3-mkl-3
you may writevasp5/5.3/openmpi-1.4
orvasp5/5.3
, letting the system choose the versions for MPI and compiler that are chosen as defaults at a given time.
Renamed modules
For the following modules the newer naming convention allowed for and thus uses more consistent names:
OLD NEW
asap3 asap/3
ase2 ase/2
ase3 ase/3
g09 gaussian/09
GaussView gaussview (lowercase)
- The modules
fftw3
andvasp5
did not change name due to more entrenched usage in the package itself, Unix group names, and compilation dependencies.
Determining default module versions
The module avail
command under CentOS-6 no longer includes the marker "(default)"
when one has been set in a .version
file.
I am not sure if this is a bug or by design, but the change certainly makes the output more consistent.
To determine which module will be loaded when an abbreviated name is used, I recommend to inspect the first relevant line in the output of one of these commands:
module show name module help name
Customizing module selection by OS release
Configure in .bashrc
To switch over to new-style module names on both CentOS releases you could continue making all your module choices in ~/.bashrc
- Tell CentOS-5 nodes to offer the new-style module catalog instead of the old one. To do so, simply create an empty customization file:
touch ~/.modules-2
- Then, apply the changes shown in the #Name change rules section above:
vi .bashrc
# or:
nano .bashrc
- Use a text editor of your choice, such as
nano
orvi
Configure in dedicated files
It is perhaps cleaner to perform the module selection in files dedicated for each CentOS release, so that you can better address possible incompatibilities. To migrate your existing configuration:
- Extract and copy your previous module selections into a conspicuously named but otherwise unused files:
cd # Go to home directory
grep -C 1 module .bashrc > .modules-1.inactive
- The
grep -C
option includes the given number of lines of context before and after lines matching the search expression.
- Clean up errant lines that the grep command above might have included, such as separators
and conditionals (likeif
vi .modules-1.inactive
# or:
nano .modules-1.inactive
- Duplicate the file.
- Adapt contents to new module names, as shown for
.bashrc
in the previous section.
cp .modules-1.inactive .modules-2.inactive
vi .modules-2.inactive
# or:
nano .modules-2.inactive
- Apply the changes shown in the #Rules section.
- Edit
~/.bashrc
and remove all lines withmodule
commands.
vi .bashrc
- Test.
bash -l # open a sub-shell (option is lowercase L)
module list
exit # leave the sub-shell
Differentiate module selection by OS release
If you encounter difficulties with making your module selection work simultaneously for CentOS-5 and CentOS-6, use separate configurations instead.
- Re-activate the older module selection.
mv .modules-1.inactive .modules-1
- Clean up errant lines:
vi .modules-1
# or:
nano .modules-1
- Test – same as in previous section.
