HPC/Module naming scheme 2016
Configuration files used
| You have files: .bashrc and … |
Remark | CentOS-5 uses: | CentOS-6 uses: | |||
| files | module names | files | module names | |||
| – | – | Starting situation. | .bashrc only | old | .bashrc only | new |
| – | .modules-2 | Switch over, recommended. | .modules-2 and .bashrc | new | .modules-2 and .bashrc | |
| .modules-1 | – | Only recommended during transition. | .modules-1 and .bashrc | old | .bashrc only | |
| .modules-1 | .modules-2 | For advanced users. | .modules-1 and .bashrc | old | .modules-2 and .bashrc | |
New-style module names
You may need to adapt the module names that you placed in your shell startup and job files to the new more hierarchical names.
General name change rules
- To use the latest or automatically selected version of a package, remove version numbers from old-style module names of the form
packagename/version, leaving onlypackagename. This is the recommended approach, as you will automatically benefit from future updates and maintenance builds. - To insist on a specific version for a package in new style names:
- Inspect the available flavors and versions (some older modules were not migrated):
module avail packagename.
- Choose the new-style name up to the desired specificity. You may leave out trailing name or directory parts.
- For instance, instead of
vasp5/5.3/openmpi-1.4/intel/5.3.3p3-mkl-3you may writevasp5/5.3/openmpi-1.4orvasp5/5.3, letting the system choose the versions for MPI and compiler that are chosen as defaults at a given time.
Renamed modules
For most modules the leading name component (the part before any "/") is the same in the old and new naming schemes. For the following modules, however, the newer naming convention allowed for and thus uses more consistent names:
OLD NEW
asap3 asap/3
ase2 ase/2
ase3 ase/3
g09 gaussian/09
GaussView gaussview (lowercase)
Customizing module selection by OS release
Configure in .bashrc
To switch over to new-style module names on both CentOS releases you could continue making all your module choices in ~/.bashrc.
- Tell CentOS-5 nodes to offer the new-style module catalog instead of the old one. To do so, simply create an empty customization file:
touch ~/.modules-2
- Then, apply the changes shown in the #Rules section:
vi .bashrc
# or:
nano .bashrc
- Use a text editor of your choice, such as
nanoorvi.
Configure in dedicated files
It is perhaps cleaner to perform the module selection in files dedicated for each CentOS release, so that you can better address possible incompatibilities. To migrate your existing configuration:
- Extract and copy your previous module selections into a conspicuously named but otherwise unused file, e.g.,
.modules-1.inactive.
cd # Go to home directory
grep -C 1 module .bashrc > .modules-1.inactive
- The
grep -Coption includes the given number of lines of context before and after lines matching the search expression.
- Duplicate the file.
cp .modules-1.inactive .modules-2
- Adapt contents to new module names, just as shown for
.bashrcin the previous section. Clean up errant lines that the grep above might have included.
vi .modules-2
# or:
nano .modules-2
- Apply the changes shown in the #Rules section.
- Edit
~/.bashrcand remove all lines withmodulecommands.
vi .bashrc
- Test.
bash -l # open a sub-shell (option is lowercase L)
module list
exit # leave the sub-shell
Differentiate module selection by OS release
If you encounter difficulties with making your module selection work simultaneously for CentOS-5 and CentOS-6, use separate configurations instead.
- Re-activate the older module selection.
mv .modules-1.inactive .modules-1
- Clean up errant lines:
vi .modules-1
# or:
nano .modules-1
- Test – same as in previous section.
