HPC/Module naming scheme 2016
< HPC
Configuration files used
| You have files: .bashrc and … |
Remark | CentOS-5 uses: | CentOS-6 uses: | |||
| module names | files | module names | files | |||
| – | – | Starting situation. | old | .bashrc only | new | .bashrc only |
| – | .modules-1 | Switch over, recommended. | new | .modules-1 and .bashrc | .modules-1 and .bashrc | |
| .modules-0 | – | Avoid! – file ignored on EL6. | old | .modules-0 and .bashrc | .bashrc only | |
| .modules-0 | .modules-1 | For advanced users. | old | .modules-0 and .bashrc | .modules-1 and .bashrc | |
New-style module names
You may need to adapt module names you use in your files to new, more hierarchical, names.
General name change rules
- To use the latest or automatically selected version of a package, remove version numbers from old-style module names of the form
packagename/version, leaving onlypackagename. This is the recommended approach, as you will automatically benefit from future updates and maintenance builds. - To insist on a specific version for a package in new style names:
- Inspect the available flavors and versions (some older modules were not migrated):
module avail packagename.
- Choose the new-style name up to the desired specificity. You may leave out trailing name or directory parts.
- For instance, instead of
vasp5/openmpi-1.4/intel/5.3.3p3-mkl-3writevasp5/openmpi-1.4
Renamed modules
OLD NEW
asap3 asap/3
ase2 ase/2
ase3 ase/3
g09 gaussian/09
GaussView gaussview
vasp vasp/4
vasp5 vasp/5
- Note: Licensees of Vasp-4 only must specify vasp/4. The default module for "vasp" is under vasp/5.
Configure in .bashrc
To switch over to new-style module names on both CentOS releases you could continue making all your module choices in ~/.bashrc.
vi .bashrc
# or:
nano .bashrc
- Apply the changes shown in the #Rules section.
- Tell CentOS-5 nodes to offer the new-style module catalog instead of the old one. To do so, simply create an empty customization file:
touch ~/.modules-el6
Configure in dedicated files
It is perhaps cleaner to perform the module selection in files dedicated for each CentOS release, so that you can better address possible incompatibilities. To migrate your existing configuration:
- Move your previous module selections into a conspicuously named but otherwise unused file, e.g.,
.modules-el5.inactive.
cd # Go to home directory
grep -A 1 module .bashrc > .modules-el5.inactive
- Duplicate the file.
cp .modules-el5.inactive .modules-el6
- Adapt contents to new module names, just as shown for
.bashrcin the previous section. Clean up errant lines that the grep above might have included.
vi .modules-el6
# or:
nano .modules-el6
- Edit
~/.bashrcand remove all lines withmodulecommands.
vi .bashrc
- Test.
bash -l # open a sub-shell (option is lowercase L)
module list
exit # leave the sub-shell
Make module selection different by OS release
If you encounter difficulties with making your module selection work simultaneously for CentOS-5 and CentOS-6, use separate configurations instead.
- Re-activate the older module selection.
mv .modules-el5.inactive .modules-el5
vi .modules-el5 # clean up errant lines
- Test – same as in previous section.
