HPC/Module naming scheme 2016
From CNM Wiki
Configuration files used
You have files:
.bashrc and …
Remark CentOS-5 uses: CentOS-6 uses:
module names files module names files
Starting situation. old .bashrc only new .bashrc only
.modules-el6 Switch over, recommended. new .modules-el6 and .bashrc .modules-el6 and .bashrc
.modules-el5 Avoid! – file ignored on EL6. old .modules-el5 and .bashrc .bashrc only
.modules-el5 .modules-el6 For advanced users. old .modules-el5 and .bashrc .modules-el6 and .bashrc
New-style module names
You may need to adapt module names you use in your files to new, more hierarchical, names.
General name change rules
  • To use the latest or automatically selected version of a package, remove version numbers from old-style module names of the formpackagename/version, leaving only packagename. This is the recommended approach, as you will automatically benefit from future updates and maintenance builds.
  • To insist on a specific version for a package in new style names:
    • Inspect the available flavors and versions (some older modules were not migrated):
      module avail packagename.
    • Choose the new-style name up to the desired specificity. You may leave out trailing name or directory parts.
      For instance, instead of vasp5/openmpi-1.4/intel/5.3.3p3-mkl-3 write vasp5/openmpi-1.4
Renamed modules
OLD		NEW
asap3		asap/3
ase2		ase/2
ase3		ase/3
g09		gaussian/09
GaussView	gaussview
vasp		vasp/4
vasp5		vasp/5
Configure in .bashrc
To switch over to new-style module names on both CentOS releases you could continue making all your module choices in ~/.bashrc.
vi .bashrc
# or:
nano .bashrc
Apply the changes shown in the #Rules section.
  • Tell CentOS-5 nodes to offer the new-style module catalog instead of the old one. To do so, simply create an empty customization file:
touch ~/.modules-el6
Configure in dedicated files
It is perhaps cleaner to perform the module selection in files dedicated for each CentOS release, so that you can better address possible incompatibilities. To migrate your existing configuration:
  • Move your previous module selections into a conspicuously named but otherwise unused file, e.g., .modules-el5.inactive.
cd      # Go to home directory
grep -A 1  module .bashrc > .modules-el5.inactive
  • Duplicate the file.
cp .modules-el5.inactive .modules-el6
  • Adapt contents to new module names, just as shown for .bashrc in the previous section. Clean up errant lines that the grep above might have included.
vi .modules-el6
# or:
nano .modules-el6
  • Edit ~/.bashrc and remove all lines with module commands.
vi .bashrc
  • Test.
bash -l     # open a sub-shell (option is lowercase L)
module list
exit        # leave the sub-shell
Make module selection different by OS release
If you encounter difficulties with making your module selection work simultaneously for CentOS-5 and CentOS-6, use separate configurations instead.
  • Re-activate the older module selection.
mv .modules-el5.inactive .modules-el5
vi .modules-el5    # clean up errant lines
