HPC/Module naming scheme 2016
From CNM Wiki
Configuration files used
You have files:
.bashrc and …
Remark CentOS-5 uses CentOS-6 uses
module names files module names files
current situation old .bashrc only new .bashrc only
.modules-carbon-1 avoid old .modules-carbon-1 and .bashrc .bashrc only (.*-1 file is ignored)
.modules-carbon-2 switch over, recommended new .modules-carbon-2 and .bashrc .modules-carbon-2 and .bashrc
.modules-carbon-1 .modules-carbon-2 for advanced users old .modules-carbon-1 and .bashrc .modules-carbon-2 and .bashrc
Configuration steps
CentOS-independent module selection (recommended)
To switch over to new hierarchical module names on both CentOS releases it's easiest to continue making all your module choices in ~/.bashrc, but you have to signal on the older platform to use the new module style:
  1. Create a customization file for new names, but leave it empty (you'll configure your choices in the next step). Use the command:
    touch ~/.modules-carbon-2
  2. Edit your .bashrc file and update your module selections as follows:
    • Remove version numbers from module names of the old-style packagename/version, leaving only packagename. This is the recommended approach, as you will automatically benefit from future versions.
    • To insist on a specific version for a pacakge affected by the new-style names, use the form packagename/compilername/version or packagename/mpiname/compilername/version as appropriate. To see available flavors and versions, separately run the command module avail packagename.
CentOS-dependent module selection
If you encounter difficulties with making your module selection work in both CentOS-5 and CentOS-6, use separate configurations:
  1. Move all your previous module commands from .bashrc to ~/.modules-carbon-1, where they will apply only on CentOS-5.
  2. Place all your module selections for CentOS-6 in ~/.modules-carbon-2. To begin, copy the .*-1 file as *.2 and edit the latter.
New and changed features
Module dependencies
New-style modules are less implicit (less automatic) in loading modules that they depend on. This means prior to loading a more advanced module you must load all its prerequisites, chosen from the same MPI and (usually) compiler flavor as the advanced module. A missing prerequisite will give errors of the form
… ERROR:151: Module 'troubled_name' depends on one of the module(s) 'other_name1 other_name2' …
To resolve this error, edit your ~/.bashrc or .modules-carbon-2 file and add module load … commands for the needed module(s) other_names before loading "troubled_name".
Name completion
When working interactively in a terminal, you can use a "completion" feature of the Bash shell to complete a partially typed module name and show all names available for the name typed so far. For example:
At a shell prompt (shown as "$"), type:
$ module load fft
Press the <TAB> key and the name will be expanded to fftw3/ and you'll see two possible completing names, with the cursor waiting at the end of the longest common substring:
$ module load fftw3/_
fftw3/INTEL/3.3.2-1              fftw3/OPENMPI-1.4/INTEL/3.3.2-4
Type the letter O, hit the <TAB> key again, and the now single complete name will be completed, with the cursor waiting after an additional space character:
$ module load fftw3/O<TAB>
$ module module load fftw3/OPENMPI-1.4/INTEL/3.3.2-4 _
Ignoring system defaults
By default, on Carbon the Intel compilers and the OpenMPI flavor of MPI continue to be pre-loaded for you. In other words, without any module customization, you'd see from the module list command:
module list
Currently Loaded Modulefiles:
  1) intel/15/15.0.2                     2) openmpi/1.4/INTEL/1.4.5-intel12-2
You can now safely use the command
module purge
and afterwards use module load … to only load your preferred compiler and MPI flavors, and applications depending on them.
