HPC/Module naming scheme 2016
From CNM Wiki
< HPC
Revision as of 19:19, August 10, 2015 by Stern (talk | contribs) (Recommendation)
You have files Remark CentOS-5 uses CentOS-6 uses
names files names files
current situation old .bashrc only new .bashrc only
.modules-carbon-1 avoid old .modules-carbon-1 and .bashrc .bashrc only (.*-1 file is ignored)
.modules-carbon-2 switch over, recommended new .modules-carbon-2 and .bashrc .modules-carbon-2 and .bashrc
.modules-carbon-1 .modules-carbon-2 for advanced cases old .modules-carbon-1 and .bashrc .modules-carbon-2 and .bashrc
Switching procedure
To switch over to hierarchical names on both CentOS releases:
  1. Create a customization file for new names, but leave it empty (you'll configure your choices in the next step). Use the command:
    touch ~/.modules-carbon-2
  2. Edit your .bashrc file and update your module selections as follows:
    • Remove version numbers from module names of the old-style name/version, leaving only name. This is the preferred approach, as you will automatically benefit from future upgrades.
    • To insist on a specific version using new-style names, append …/mpiname/compilername/version as needed. To see available flavors and versions, separately run the command module avail name.
Module Dependencies
New-style modules are less implicit (less automatic) in loading modules that they depend on. This means prior to loading a more advanced module you must load all its prerequisites, chosen from the same MPI and (usually) compiler flavor as the advanced module. A missing prerequisite will give errors of the form
… ERROR:151: Module 'troubled_name' depends on one of the module(s) 'other_name1 other_name2' …
To resolve this error, edit your ~/.bashrc or .modules-carbon-2 file and add module load … commands for the needed module(s) other_names before loading "troubled_name".
Name completion
When working interactively in a terminal, you can use a "completion" feature of the Bash shell to complete a partially typed module name and show all names available for the name typed so far. For example:
At a shell prompt (shown as "$"), type:
$ module load fft
Press the <TAB> key and the name will be expanded to fftw3/ and you'll see two possible completing names, with the cursor wating at the end of the longest common substring:
$ module load fftw3/_
fftw3/INTEL/3.3.2-1              fftw3/OPENMPI-1.4/INTEL/3.3.2-4
Type the letter O, hit the <TAB> key again, and the now single complete name will be completed, with the cursor waiting after an additional space character:
$ module load fftw3/O<TAB>
$ module module load fftw3/OPENMPI-1.4/INTEL/3.3.2-4 _
