HPC/Hardware Details
< HPC
User nodes
Carbon has many major node generations, named genN for short, with N being an integer. In some generations, nodes differ further by the amount of memory.
Node Types
| Node names, types |
Node generation |
Node extra properties |
Node count |
Cores per node (max. ppn)
Cores total, by type |
Account charge rate |
CPU model |
CPUs per node |
CPU nominal clock (GHz) |
Mem. per node (GB) |
Mem. per core (GB) |
GPU model |
GPU per node |
VRAM per GPU (GB) |
Disk per node (GB) |
Year added |
Note |
| Login | |||||||||||||||||
| login5…6 | gen7a | gpus=2 | 2 | 16 | 32 | 1.0 | Xeon Silver 4125 | 2 | 2.50 | 192 | 12 | Tesla V100 | 2 | 32 | 250 | 2019 | |
| Compute | |||||||||||||||||
| n421…460 | gen5 | 40 | 16 | 640 | 1.0 | Xeon E5-2650 v4 | 2 | 2.10 | 128 | 8 | 250 | 2017 | |||||
| n461…476 | gen6 | 16 | 16 | 256 | 1.0 | Xeon Silver 4110 | 2 | 2.10 | 96 | 6 | 1000 | 2018 | |||||
| n477…512 | gen6 | 36 | 16 | 576 | 1.0 | Xeon Silver 4110 | 2 | 2.10 | 192 | 12 | 1000 | 2018 | |||||
| n513…534 | gen7 | gpus=2 | 22 | 32 | 704 | 1.5 | Xeon Gold 6226R | 2 | 2.90 | 192 | 6 | Tesla V100S | 2 | 32 | 250 | 2020 | |
| n541…580 | gen8 | 20 | 64 | 2560 | 1.0 | Xeon Gold 6430 | 2 | 2.10 | 1024 | 16 | 420 | 2024 | |||||
| Total | 134 | 4736 | 48 | ||||||||||||||
- Compute time is charged as the product of cores reserved × wallclock time × charge rate. The charge rate accommodates nominal differences in CPU speed.
- gen7 nodes have two GPUs each; GPU usage is currently not "charged" (accounted for) separately.
- Virtual memory usage on nodes may reach up to about 2 × the physical memory size. Your processes running under PBS may allocate that much vmem but cannot practically use it all for reasons of swap space size and bandwidth. If a node acitvely uses swap for more than a few minutes (which drastically slows down compute performance), the job will automatically be killed.
Major CPU flags
CPU capabilities grow with each node generation. Executables can be compiled to leverage specific CPU capabilities. Jobs using such executables must use the qsub option -l nodes=...:genX to be directed to nodes having that capability.
| Flag name | gen5 | gen6 | gen7 | gen8 |
| cat_l2 cdp_l2 cldemote gfni movdir64b movdiri pconfig sha_ni umip vaes vpclmulqdq | – | – | – | x |
| avx512_bitalg | – | – | – | x |
| avx512_vbmi2 | – | – | – | x |
| avx512_vpopcntdq | – | – | – | x |
| avx512ifma | – | – | – | x |
| avx512vbmi | – | – | – | x |
| avx512_vnni | – | – | x | x |
| mpx | – | x | x | – |
| avx512bw | – | x | x | x |
| avx512cd | – | x | x | x |
| avx512dq | – | x | x | x |
| avx512f | – | x | x | x |
| avx512vl | – | x | x | x |
| art clwb flush_l1d ibpb mba md_clear ospke pku ssbd stibp tsc_deadline_timer xgetbv1 xsavec | – | x | x | x |
| 3dnowprefetch abm acpi aes aperfmperf apic arat arch_perfmon bmi1 bmi2 bts cat_l3 cdp_l3 cmov constant_tsc cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc cx16 cx8 dca de ds_cpl dtes64 dtherm dts eagerfpu epb ept erms est f16c flexpriority fpu fsgsbase fxsr hle ht ida invpcid invpcid_single lahf_lm lm mca mce mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdt_a rdtscp rep_good rsb_ctxsw rtm sdbg sep smap smep smx ss sse sse2 sse4_1 ssse3 syscall tm tm2 tpr_shadow tsc tsc_adjust vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr | x | x | x | x |
| avx | x | x | x | x |
| avx2 | x | x | x | x |
| fma | x | x | x | x |
| adx | x | x | x | x |
| sse4_2 | x | x | x | x |
Storage
- Lustre parallel file system for /home and /sandbox
- ≈100 TB total
- local disk per compute node, 160–250 GB
Interconnect
- Infiniband DDR/QDR (for gen3) – used for parallel communication and storage
- Ethernet 1 GB/s – used for general node access and management
Power
- Power consumption at typical load: ≈125 kW
