HPC/FAQ
Login issues
When you ask "I cannot log in" or "My password does not work", consider the following sections:
Review host names
Make sure you connect to the correct host name, which is mega.cnm.anl.gov for the SSH gateway and carbon.cnm.anl.gov when connecting from an onsite work computer or over VPN. The previous name for the latter was clogin.cnm.anl.gov and will continue to work. -- See HPC/Network Access.
Verify your password
Visit https://credentials.anl.gov/ and verify that your username and password are correct.
Review access requirements
To access Carbon under the CNM User Program, a number of items are required, most of which are subject to an expiration date and require periodic renewal.
- Review and update your User Registration.
- Your Argonne computer account will be disabled upon expiration of certain registration items. In particular, if you are not a US citizen, you will require a current US visa or related work permit to access Argonne computers, just as if you were to visit in person. This will very likely happen in the middle of your proposal's lifetime. For some of these expirations, no notice will be sent to you (for varying reasons), and you will suddenly find that you can no longer access mega.
- After you updated your user registration, contact the CNM User Office to have your Argonne account re-instated.
- Renew your User Courses.
- For remote users, the ESH223 course "Cybersecurity Annual Education and Awareness" is the one most likely in need of renewal.
- You must be a participant in at least one active or recently expired User Proposal.
- To review dates for your proposal, ask your PI to search their email archive for mails with "Work Approval Received" or "Proposal Expiration" in the subject.
- Compute jobs may be run while a proposal (specifically, the user work authorization) is active. For at least 30 days thereafter, users are entitled to data access only, following CNM's Data Retention Policy.
- Access to mega requires that the User Work Submittal for a proposal contain your badge number.
- This is a more arcane technical issue. If your badge number was left empty at the original submission of the UWS (typically when you are a newly registered user), ask the CNM User Office or your Scientific Contact to augment and resubmit the form.
Request a password reset
- To have your password reset, email the CNM User Office, at [email protected].
- When you connect to mega with still your temporary password in place, mega will ask for a new password. You can safely change your password at this point.
- You can also change your password at https://credentials.anl.gov/ - However, a change there will take a few hours to become active on mega.
Review instructions
- Read again HPC/Network Access, and follow the instructions for your platform.
Practical hints
- After you were added to a user proposal, wait at least an hour or more before trying to access mega.
- Updates of your status need to be propagated through a handful of systems, each being done about hourly, so it may take several cycles for your status change to reach mega.
- Set yourself calendar entries about one year into the future to remind yourself to renew any of your user registration or training requirements.
Mailing lists
Announcements about Carbon are made on the cnm-hpc-announce mailing list, hosted at Argonne. These list pages and the archive are, unfortunately, only accessible from onsite or via VPN.
- To unsubscribe from the mailing list, send a blank message to cnm-hpc-announce-leave@lists.anl.gov and follow up on the confirmation notice.
- To update your email address on the list, simply unsubscribe as shown in the previous item, then re-subscribe by sending a blank message to cnm-hpc-announce-join@lists.anl.gov.
- See the GNU Mailman documenation for background.
Applications
I'd like to use application X
- Check if the application is already available on Carbon
Either:
- Browse the Application Catalog, or
- View the catalog on the Carbon command line:
module avail module -l avail 2>&1 | less
- The second form gives you browsable output.
- If you cannot find the application on Carbon
- Describe the problem you are trying to solve – it may well be that we can suggest an alternative solution.
- Provide one or more URLs relevant to software you have in mind – be specific.
How do I run application X?
- Customize your shell environment to load the application module.
- Learn about module conventions on Carbon.
- To determine the names of a package's executable scripts and binaries, load the application module (if you have not yet done so in your shell setup), then inspect the module's
$NAME_HOME/bin
directory. For instance, for the Quantum-ESPRESSO package:
module load quantum_espresso
ls $QUANTUM_ESPRESSO_HOME/bin
- Learn how to submit and manage jobs.
How do I use application X?
Read the package's documentation, using one or more of the following:
- Inspect the package's
$NAME_HOME/share
or$NAME_HOME/doc
directory on Carbon (see module conventions). - Browse the package's web page, generally mentioned in the
module help
text or the application catalog entry. - Consult a package's man pages. Few packages have them. Man page files are generally installed under
$NAME_HOME/man
or$NAME_HOME/share/man
and if so, will be made available automatically to theman
command.
What's my account balance?
Simple answer: mybalance
To find out how many core-hours you have available, the simplest command to run is:
mybalance -h
Project Machines Balance -------- -------- ---------- user ANY 993.26 cnm34567 ANY 158760.93 cnm31234 ANY -148893.62
The table gives all the Project
s you have access to (for use with the qsub -A
argument), and their balance.
Machine
lists all systems that can book jobs against your allocations. Carbon is currently the only machine that can do so.
Balance
is your account balance, in core-hours, as selected by the -h command option. This is the most useful and recommended unit.
Without -h, you get core-seconds, which are integers but rather more unwieldy numbers.
- The "user" project provides you with a small initial startup allocation of typically 1000 core-hours.
- When a Balance is reported as negative, that account typically has a CreditLimit assigned, which permits the balance to dip below zero. These details, however, are not shown by
mybalance
Complete answer: gbalance
To get allocation details for accounts that have CreditLimits, run the gbalance
command. Pass on -u username or -p projectname to select your allocations:
gbalance -h -u $USER
- Use the literal string
$USER
which makes the shell fill in your actual username.
The ouput looks like:
Id Name Amount Reserved Balance CreditLimit Available --- -------- ---------- -------- ---------- ----------- --------- 100 cnm31234 -148893.62 0.00 -148893.62 150000.00 1106.38 217 kpelzer 993.26 0.00 993.26 0.00 993.26 123 cnm34567 166440.93 7680.00 158760.93 0.00 158760.93
The most relevant column for you is Available. The units, given the -h option, are again core-hours.
The colums and their meanings are:
- Id
- an internal number for the account.
- Name
- The project name (for use with
qsub -A
or#PBS -A
). - Amount
- Amount for transactions completely on the books for the project account; does not include running jobs or credits. Deposits are allocated by the User Office and implemented by the Carbon administrator.
- Reserved
- Amounts held in reserve by all running jobs using this account. The reserve ensures that a job does not cause an overdraft when it finishes and when its actual use will be booked. The quantity is calculated by walltime * number of cores blocked. When a job terminates, the charge according to the actual time used will be subtracted from Amount, and the unused quantities will be re-added to Amount.
- Balance
- Available for new jobs; may go negative if CreditLimits are in place.
Balance = Amount - Reserved
- CreditLimit
- Amount by which Balance may go negative; assigned by the Carbon administrator.
- Available
- Relevant quantity for new jobs. Must be positive for a new job to start, and large enough to Reserve the entire job.
Available = Balance + CreditLimit
My question is not answered here
See HPC/Support.
