HPC/Applications/matlab
From CNM Wiki
Revision as of 23:47, March 7, 2014 by Stern (talk | contribs)
Licensing
MATLAB is available on Carbon on request, and is subject to strictly limited license terms. Running MATLAB is restricted to:
  • Argonne employees (including consultants and students),
  • by one user at a time.
Toolboxes
We have the following toolboxes installed:
  • Curve Fitting Toolbox
  • Image Processing Toolbox
  • Optimization Toolbox
  • Parallel Computing Toolbox
  • Statistics Toolbox
Alternatives
Given licensing and availability limitations of MATLAB you may wish to consider using alternative solutions, especially for new projects.
Octave
If you have existing MATLAB code, try running in using GNU Octave instead of MATLAB for all but the most demanding or vendor-specific tasks:
  • To start octave:
octave
Python or Perl
For more flexibility, use a general-purpose scripting language.
NLopt – Nonlinear optimization
For users wishing to solve nonlinear optimization problems, the nlopt module is a fairly general-purpose optimization library with interfaces in C, C++ and Fortran.
Running MATLAB
  • To get started, load the "matlab" module as described at HPC/Module Setup.
  • Then choose how to run the application:
GUI
matlab
Command line
For basic calculations, you could save some startup time by simply using the text interface.
matlab -nojvm
Does not load the Java VM and toolboxes requiring any java.
or
matlab -nodisplay
Suppresses X11.
Using the MATLAB compiler
The MATLAB compiler, available on Carbon, allows you to create standalone Linux binaries that do not need a MATLAB license token to run.
For documentation, see HPC/Applications/matlab/Compiler.
Parallel toolkit
See HPC/Applications/matlab/Parallel.
Troubleshooting
Access
To run MATLAB on Carbon, you must be a member of the "employees" group. You could still load the "matlab" module if you are not, but it will not enable anything.
  • To inspect your current group membership, run:
groups
The word "employees" must show.
License in use
License checkout failed.
License Manager Error -9
This error may occur when:
-The hostid of this computer does not match the hostid in the license file.
-A Designated Computer installation is in use by another user.
If no other user is currently running MATLAB, you may need to activate.
Solution:
  • Wait a few minutes or hours.
  • For urgent request, to locate and possibly terminate an existing session, Send a support request.
