HPC/Applications/matlab
Alternatives
MATLAB is vendor-specific, and comparably expensive licensed software and thus not generally available. Consider using an unencumbered alternative solution.
Octave
If you have existing MATLAB code, try running in using GNU Octave instead of MATLAB for all but the most demanding or vendor-specific tasks:
- To start octave:
octave
- GNU Octave Documentation
- Differences between Octave and MATLAB in the WikiBook MATLAB Programming (slightly out of date).
- Why/when should I prefer MATLAB over Octave? – Discussion at stackoverflow.com.
Python or Perl
For more flexibility, use a general-purpose scripting language.
- Most users may want to look at Python with NumPy, available as module "numpy" on Carbon. See also:
- Users who like a stonger Unix flavor should look at Perl.
NLopt – Nonlinear optimization
For users wishing to solve nonlinear optimization problems, the nlopt module is a fairly general-purpose optimization library with interfaces in C, C++ and Fortran.
Licensing
MATLAB is available on Carbon on request, and is subject to strictly limited license terms. Running MATLAB is restricted to:
- Argonne employees (including consultants and students),
- by one user at a time.
Toolboxes
We have the following toolboxes installed:
- Curve Fitting Toolbox
- Image Processing Toolbox
- Optimization Toolbox
- Parallel Computing Toolbox
- Statistics Toolbox
Running MATLAB
- To get started, load the "matlab" module as described at HPC/Module Setup.
- Then choose how to run the application:
- GUI
matlab
- Command line
- For basic calculations, you could save some startup time by simply using the text interface.
matlab -nojvm
- Does not load the Java VM and toolboxes requiring any java.
or
matlab -nodisplay
- Suppresses X11.
Running the MATLAB compiler
See HPC/Applications/matlab/Compiler
Parallel toolkit
- http://www.mathworks.com/help/distcomp/
- or http://www.mathworks.com/help/releases/R2013a/distcomp/
- http://www.mathworks.com/help/distcomp/release-notes.html?searchHighlight=matlabpool
- parpool: New command-line interface (replaces matlabpool)
- http://www.mathworks.com/help/mdce/release-notes.html?searchHighlight=matlabpool
- Same, plus: Discontinued Support for parallel.cluster.Mpiexec
- Automatic start of a parallel pool when executing code that uses parfor or spmd
An error has occurred processing your job, see below. Post job file processing error; job 435379.sched1.carboncluster on host n189/7+n189/6+…+n187/0 Unable to copy file /var/spool/torque/spool/435379.sched1.carboncluster.OU to /home/stern/somedir/Job1/Job1.log *** error from copy /bin/cp: cannot create regular file `/home/stern/somedir/Job1/Job1.log': No such file or directory *** end error output Output retained on that host in: /var/spool/torque/undelivered/435379.sched1.carboncluster.OU
Troubleshooting
Access
To run MATLAB on Carbon, you must be a member of the "employees" group. You could still load the "matlab" module if you are not, but it will not enable anything.
- To inspect your current group membership, run:
groups
- The word "employees" must show.
License in use
License checkout failed. License Manager Error -9 This error may occur when: -The hostid of this computer does not match the hostid in the license file. -A Designated Computer installation is in use by another user. If no other user is currently running MATLAB, you may need to activate.
Solution:
- Wait a few minutes or hours.
- For urgent request, to locate and possibly terminate an existing session, Send a support request.
