HPC/FAQ
< HPC
"I cannot log in"
- Make sure you connect to the correct host names, namely mega.cnm.anl.gov for the SSH gateway and clogin.cnm.anl.gov when onsite. Do not use "carbon".
- Access to mega requires an active proposal. Access will be disabled 6 weeks after your last active proposal expired. To identify such times, scan your email archive for mails containing the words "Work Approval Received" in the subject.
- Users who are non-US citizens require a current visa for access. On expiration, your Argonne login will be disabled, possibly in the mddle of a proposal lifetime, and you may suddenly find you can no longer access mega. Review and renew your details at https://beam.aps.anl.gov/pls/apsweb/ufr_main_pkg.usr_start_page .
- Visit https://credentials.anl.gov/ and verify that your username and password are correct.
- To have your password reset, email the CNM User Office, at [email protected].
- It may take about 1–3 hours for a proposal to be recognized as active again on mega.
- Carefully re-read HPC/Network Access, and follow the instructions for your platform.
"I'd like to use program X"
Check if the application is already available on Carbon
Either:
- Browse the Application Catalog, or
- View the catalog on the Carbon command line:
module avail module -l avail 2>&1 | less
- The second form gives you browsable output.
If you cannot find the application
- Describe the problem you are trying to solve – it may well be that we can suggest an alternative solution.
- Provide one or more URLs relevant to the software – be specific.
To report a problem
Send mail to [email protected]
Consider the following advice:
- How To Ask Questions The Smart Way, by Eric S. Raymond, open source pioneer.
- How to Report Bugs Effectively, by Simon Tatham, programmer.
Report network and connectivity issues
Include the following:
- Your operating system and version.
- The software name and version you use to connect (e.g. SSH or VNC).
- The command you are trying to run or the menu item you choose.
- The hostname you're trying to reach and the username.
- The error message you get (Copy & Paste the message text, or take a screenshot)
