HPC/Applications/lammps/Package USER-CUDA
From CNM Wiki
Revision as of 15:21, June 25, 2013 by Stern (talk | contribs) (Stern moved page HPC/Modules/lammps/Package USER-CUDA to HPC/Applications/lammps/Package USER-CUDA)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
Package USER-CUDA
  • Provides GPU versions of several pair styles and for long-range Coulombics via the PPPM command.
  • Only supports a single CPU (core) with each GPU [That should mean multiple nodes are possible; feasibility and efficiency to be determined --stern ]
Usage
  1. Optional: Use the command package cuda keyword value keyword value … near the beginning of your LAMMPS control script to finely control settings. This is optional since a LAMMPS binary with USER-CUDA always detects and uses a GPU by default.
  2. Do one of the following:
  3. Optional: The kspace_style pppm/cuda command has to be requested explicitly. [I am not sure if that means that other k-space styles implicitly use the GPU --stern. ]
  4. In the job file or qsub command line, request a GPU #PBS -l nodes=...:gpus=1.
  5. Call the lmp_openmpi-user-cuda binary.
Input file example
Examples:
package cuda gpu/node/special 2 0 2
package cuda test 3948
kspace_style    pppm/cuda 1e-5
Job file example
  • Serial job:
#PBS -l nodes=1:ppn=1:gpus=1
lmp_openmpi-user-cuda -suffix cuda -in infile
  • Parallel job; note that ppn must still be 1 as only one LAMMPS process (core) per node can use the sole GPU.
#PBS -l nodes=3:ppn=1:gpus=1
mpirun -machinefile $PBS_NODEFILE -np $PBS_NP lmp_openmpi-user-cuda -suffix cuda -in infile
