HPC/Applications/lammps/Package OMP
From CNM Wiki
Revision as of 15:21, June 25, 2013 by Stern (talk | contribs) (Stern moved page HPC/Modules/lammps/Package OMP to HPC/Applications/lammps/Package OMP)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
Package OMP
LAMMPS modules since 2012 are compiled with yes-user-omp, permitting multi-threaded runs of selected pair styles, and in particular MPI/OpenMP hybrid parallel runs. To set up such runs, see HPC/Submitting and Managing Jobs/Advanced node selection.
  • The number of MPI tasks running on a node is determined by options to mpirun.
  • The number of threads that each MPI task runs with is usually determined by the environment variable OMP_NUM_THREADS, which is 1 by default on Carbon.
  • The LAMMPS package omp command has a mandatory argument Nthreads to either override OMP_NUM_THREADS, or use it when set to * - the recommended practice. It appears to be sensible to specify a concrete thread number only once, which means in the job file, and let LAMMPS inherit this value with Nthreads set to *.
Usage
  1. Use the command package omp Nthreads mode near the beginning of your LAMMPS control script.
  2. Do one of the following:
  3. In the job file or qsub command line, reserve nodes and ppn suitable for OpenMP runs.
  4. Call the lmp_openmpi (regular) binary.
Input file example
Examples:
# recommended - inherit OMP_NUM_THREADS
package omp * force/neigh
# not recommended
package omp 4 force
Job file example
And for the main command:
lmp_openmpi -suffix omp -in infile
mpirun … lmp_openmpi -suffix omp -in infile
