HPC/Applications/atk/License troubleshooting on Windows
- Open a Windows command prompt.
- Inspect the current license setting.
echo %QUANTUM_LICENSE_PATH%
- You should get one of the following:
6200@localhost6200@localhost;6201@localhost
- The first entry uses one license server only, the second entry uses one of two available servers.
- If you do not see one of the above resuls, log out and log back in again, and repeat these steps from step 1 above.
- Run the following commands exactly as shown:
cd %HOMEPATH%set LMX_EXTENDEDLOG=Desktop\lmx.logset > %LMX_EXTENDEDLOG%
- You can select and Copy the string from here and Paste it into the Command Prompt window from the right-click context menu.
- Run this command, adapting it to the path you installed ATK under:
C:\"Program Files (x86)"\QuantumWise\atk-12.2.2\vnl\bin\vnl.exe
- It will take a few seconds for the command to start.
- Note: For this test only, do not start VNL by clicking on its icon in Explorer or its desktop shortcut.
- Move any VNL windows away from the command prompt window.
- Take a screenshot of your entire screen.
- Use Save Snip, Save As to produce an image file.
- Close VNL.
- Locate the lmx.log file on your Desktop. The extension may not be shown.
- Optional: To inspect the log file, open it by double-clicking. It is a text file that opens by default in Notepad.
- Send by email the lmx.log file and the screenshot from step (5)
- Close the Command Prompt window.
