HPC/Submitting and Managing Jobs/Advanced node selection
Node Types
Hardware
Carbon has two major node types, called gen1 and gen2, and gen2 is further differentiated by the amount of memory.
| Node names, types |
Node generation |
Node extra properties |
Node count |
Cores per node (max. ppn)
Cores total, by type |
Account charge rate |
CPU model |
CPUs per node |
CPU nominal clock (GHz) |
Mem. per node (GB) |
Mem. per core (GB) |
GPU model |
GPU per node |
VRAM per GPU (GB) |
Disk per node (GB) |
Year added |
Note |
| Login | |||||||||||||||||
| login5…6 | gen7a | gpus=2 | 2 | 16 | 32 | 1.0 | Xeon Silver 4125 | 2 | 2.50 | 192 | 12 | Tesla V100 | 2 | 32 | 250 | 2019 | |
| Compute | |||||||||||||||||
| n421…460 | gen5 | 40 | 16 | 640 | 1.0 | Xeon E5-2650 v4 | 2 | 2.10 | 128 | 8 | 250 | 2017 | |||||
| n461…476 | gen6 | 16 | 16 | 256 | 1.0 | Xeon Silver 4110 | 2 | 2.10 | 96 | 6 | 1000 | 2018 | |||||
| n477…512 | gen6 | 36 | 16 | 576 | 1.0 | Xeon Silver 4110 | 2 | 2.10 | 192 | 12 | 1000 | 2018 | |||||
| n513…534 | gen7 | gpus=2 | 22 | 32 | 704 | 1.5 | Xeon Gold 6226R | 2 | 2.90 | 192 | 6 | Tesla V100S | 2 | 32 | 250 | 2020 | |
| n541…580 | gen8 | 20 | 64 | 2560 | 1.0 | Xeon Gold 6430 | 2 | 2.10 | 1024 | 16 | 420 | 2024 | |||||
| Total | 134 | 4736 | 48 | ||||||||||||||
Benchmarks show that gen2 nodes are about twice as fast as gen1 nodes for memory-intensive applications. (The X5300 series is hampered by a memory bandwidth bottleneck when all 8 cores are active and frequently access memory.) Thus, gen1 nodes are charged at a discounted rate of the walltime actually used. The discount also encourages continued productive use of gen1 nodes.
Selecting node types for jobs
Jobs are directed automatically onto either gen1 or gen2 nodes, with preference for gen2 if both are available. Unless specifically requested, jobs will never mix generations. This will avoid disparate CPU speeds and MPI communication setup in a job. You can force jobs onto either node set in the job script after #PBS or on the qsub command line by suffixing the nodes= specifier with a property such as :gen1 or :gen2. For example, to run on 2 nodes with 8 cores each:
qsub -l nodes=2:ppn=8:gen1 foo.job # not recommended for VASP
qsub -l nodes=2:ppn=8:gen2 foo.job
The following are (as of now) equivalent, since "bigmem" currently implies "gen2":
qsub -l nodes=2:ppn=8:gen2:bigmem foo.job
qsub -l nodes=2:ppn=8:bigmem foo.job
See also: http://www.clusterresources.com/torquedocs21/2.1jobsubmission.shtml#resources
PPN Tricks
Each Carbon node has 8 cores, and for many jobs users indeed request entire nodes by specififying ppn=8 in the job submission.
However, you may need to request fewer cores, e.g. for the following reasons:
- your application is not parallelized,
- your application has limited hardcoded parallelization, e.g. for 2 or 4 cores only,
- your application runs multi-threaded but uses
$PBS_NODEFILEto infer the number of processes to start, - your application runs busy service processes or service threads (e.g. NWChem),
- your application saturates a resource, e.g. memory bandwidth (some large VASP calculations),
- the node's memory is exhausted by fewer application processeses than there are cores available.
Depending on the reason, the node either may be or must not be used by other jobs.
In the past, the only way to achieve exclusive but undersubscribed node access was to request ppn=8 and then to thin out a copy of the nodefile before passing it to the application.
To eliminate the need to edit the nodefile, use the -l naccesspolicy=… flag to differentiate between resources requested from Moab from those passed to the application (in $PBS_NODEFILE).
Select an option from the following scenarios.
- Permit other users and jobs
- When a job requires only a few cores and a commensurate fraction of other resources, simply specify
ppnas needed:
#PBS -l nodes=nnn:ppn=4
- In this case, the remaining cores may be allocated to other jobs, which is the default policy:
#PBS -l naccesspolicy=SHARED
- Permit only your own jobs
#PBS -l nodes=nnn:ppn=2 #PBS -l naccesspolicy=SINGLEUSER
- Permit only one job per node, no sharing
- When your job requires only a few cores but a disproportionate fraction of another resource on a node (such as most of its memory or a lot of I/O bandwidth), claim the entire node:
#PBS -l nodes=nnn:ppn=4 #PBS -l naccesspolicy=SINGLEJOB
- PBS will reserve the entire node(s), but place each node name only
ppntimes in the$PBS_NODEFILE. This is also useful for MPI+OpenMP ("hybrid") programming, see below. - Permit only one of your jobs, and permit other user's jobs
#PBS -l nodes=nnn:ppn=4 #PBS -l naccesspolicy=UNIQUEUSER
- The node is shared, but limited to one job for any given user.
Different PPN by node
- When your first MPI process (the "master" process) requires more memory than your other "worker" processes, give several
nodesspecifications, separated by a"+"character (which is unusal and born of historical necessity):
#PBS -l nodes=1:ppn=1+2:ppn=4 #PBS -l naccesspolicy=SINGLEJOB
- For clarity, the
nodesspecification in this example reads as follows:
nodes = ( 1:ppn=1 ) + ( 2:ppn=4 )
- This will request 3 node exclusively, but the first node will occur only once in the
$PBS_NODEFILE, e.g.
n011 n012 n012 n012 n012 n034 n034 n034 n034
In all of the preceding scenarios the following applies:
- The
$PBS_NODEFILEseen by the job script will always matchppn. - For accounting, the job will be billed by the number of cores blocked from use by other users, i.e.,
ncores=ppnfor shared nodes, andncores=8otherwise.
Update: memory constraints from cpusets
As of TORQUE-3.x, certain jobs on gen2 and gen3 nodes may be able to accees only half the available memory per node, even under naccesspolicy=SINGLEJOB.
The reason is that under the new cpusets feature, the memory on each node is released to a job in proportion to the number of cores requested. Specifically, gen2 and gen3 nodes have 2 memory banks, and only one of these is made accessible to jobs that have ppn ≤ nproc/2, where nproc is the number of physical cores per node.
- Workaround
- Request entire nodes from TORQUE with
ppn=8, then have MPI use fewer cores per node with thempirun -npernode Moption (M = 1 to 7), instead of the usual request for all cores in the nodefile,-np $PPN_NP.
#PBS -l nodes=N:ppn=8:gen2 ... my_ppn=3 mpirun -machinefile $PBS_NODEFILE -npernode $my_ppn \ foo-app ...
- Drawback
- This solution is specific to OpenMPI.
See also: http://www.supercluster.org/pipermail/torqueusers/2013-March/015663.html
Multithreading using OpenMP
When you wish to use multithreading, you must ensure that the total number of "busy" user threads and processes corresponds to the number of cores requested from PBS. Today, multithreading in applications and libraries is typically programmed using the OpenMP interface and the number of threads is controlled by the environment variable $OMP_NUM_THREADS.
Select from the following scenarios.
Pure OpenMP, single entire node
#PBS -l nodes=1:ppn=8
cd $PBS_O_WORKDIR
export OMP_NUM_THREADS=$PBS_NUM_PPN
programname …
Choose the number of cores n such that 1 ≤ n ≤ 8:
#PBS -l nodes=1:ppn=n
cd $PBS_O_WORKDIR
programname …
Here, the default policy "SHARED" is in effect, and OMP_NUM_THREADS is set automatically by counting the number of times that the first node occurs in $PBS_NODEFILE. This will allow you to vary or override the nodes setting using "qsub -l nodes=…" without having to edit it twice in the job file.
OpenMP/MPI hybrid
Making efficient use of multithreading on multiple nodes which communicate over MPI is fairly involved and is subject to ongoing research. Since OMP_NUM_THREADS is set to 1 by default on MPI satellite nodes, you must export this variable after you altered it in the job file.
#!/bin/bash
# Calculate number of threads available per MPI process
cores_per_node=$( grep -c ^processor /proc/cpuinfo )
OMP_NUM_THREADS=$(( cores_per_node / PBS_NUM_PPN ))
mpirun -x OMP_NUM_THREADS -machinefile $PBS_NODEFILE -np $PBS_NP \
programname …
The -x option is specific to OpenMPI; please consult the documentation to achieve the same behavior in other MPI implementations.
The last example will ensure:
- you get allocated entire nodes (SINGLEJOB policy)
- you do not oversubscribe cores (OMP_NUM_THREADS is calculated from ppn)
- you only have one place to adjust (ppn), and can do so in the command line, or even post submission
It is assumed:
- The number of cores on the first node (running the job script) is the same as on the other nodes.
- All cores on a node will be used.
Advenced: PBS_* Variables
As of Torque-3.x the following environment variables are provided in a job environment, with their value being computed, from torque-3.0.5/src/resmom/start_exec.c :
static char *variables_else[] = /* variables to add, value computed */
"HOME",
"LOGNAME",
"PBS_JOBNAME",
"PBS_JOBID",
"PBS_QUEUE",
"SHELL",
"USER",
"PBS_JOBCOOKIE",
"PBS_NODENUM",
"PBS_TASKNUM",
"PBS_MOMPORT",
"PBS_NODEFILE",
"PBS_NNODES", /* number of nodes specified by size */
"TMPDIR",
"PBS_VERSION",
"PBS_NUM_NODES", /* number of nodes specified by nodes string */
"PBS_NUM_PPN", /* ppn value specified by nodes string */
"PBS_GPUFILE", /* file containing which GPUs to access */
"PBS_NP", /* number of processors requested */
"PBS_WALLTIME", /* requested or default walltime */
NULL
