HPC/Applications/nwchem
< HPC | Applications
Introduction
Considerations on Carbon
- SCRATCH_DIR
- NWChem might use a camparably large amount of disk space in volumes and bandwidth not suitable for your $HOME directory. To avoid quota overruns, use either $SANDBOX or $TMPDIR for NWChem scratch. The *.nw input file is static, which makes it difficult to point to temporary directories via their environment vairables. As a solution, I suggest to create a symbolic link in the job script prior to running NWChem, and use the name of the job script in your *.nw file. See
$NWCHEM_HOME/sample.jobfor the full file. To the following steps:
- In the job script, set up a job-specific scratch directory as symlink named "scratch" in the job's working directory. Choose one of:
- $SANDBOX: distributed scratch (not auto-cleaned, high bandwidth but shared file system)
- $TMPDIR: node-local (auto-cleaned, slower)
- In the NWChem input file, add the line "scratch_dir ./scratch" near the beginning.
cat $NWCHEM_HOME/sample.job
#!/bin/bash
#PBS ...
dir=$SANDBOX/$PBS_JOBID
#dir=$TMPDIR
link=scratch
mkdir -p $dir
ln -snf $dir $link
mpirun -machinefile $PBS_NODEFILE -np $PBS_NP \
nwchem foo.nw
# clean sandbox (won't be reached if job terminates for time)
[[ $dir =~ $SANDBOX/* ]] && rm -r $dir
cat job.nw
title "foo structure"
echo
geometry units angstroms
- MEMORY
- The default
memoryallocation is far smaller than useful on Carbon. Raise it using, e.g.:
memory total 3200 mb
