HPC/Applications/quantum-espresso
< HPC | Applications
Introduction
Quantum ESPRESSO is a suite of several programs working on the same data files. This brings with it some challenges for data management.
- A sample job file is at the customary location once the quantum-espresso module is loaded.
$QUANTUM_ESPRESSO_HOME/sample.job
- Remove the large and numerous wave function files *.wfc* when you no longer need them.
Limitations
- QE stores rather large wave function files in the directory specified by
outdiror theESPRESSO_TMPDIRenvironment variable. This may unduly tax the file server. - Wave function files from parallel runs are written separately by each MPI process and are named
prefix.wfcnwith sequential integers n. Subsequent calculations must use the exact same number of MPI processes, and each process must have access to its own n. (That means using a node-local directory for those files is overly difficult because a dispatch stage would be needed to supply each node with the proper subset of files.) - In a subdirectory
prefix.save/the main QE program pw.x stores important metadata needed for subsequent calculations such as a DOS calculation. This means the…TMPpart in the nameESPRESSO_TMPDIRis rather misleading. - QE expects a non-trivial value of
ESPRESSO_PSEUDOto terminate with a slash/. The pw.x binary manages to accept a value without a terminating slash, but other executables such as dos.x fail.
Changes
As of module version quantum-espresso/4.3.2-2:
- Given the problems above, the environment variable
ESPRESSO_TMPDIRis no longer set. - The value of
ESPRESSO_PSEUDOnow ends with a slash. Unfortunately, the new value will be of no help for older calculations sinceprefix.save/data-file.xmlenshrines the old value. To continue with an older calculation:perl -i.bak -pe 's{/opt/soft/quantum-espresso-pot/pseudo$}{$&/}' */data-file.xml
- There will not be any output, but you can inspect the changes if you're curious:
for i in */data-file.xml; do diff $i.bak $i; done
