HPC/Applications/lammps/Package OMP
Package OMP
LAMMPS modules since 2012 are compiled with yes-user-omp, permitting multi-threaded runs of selected pair styles, and in particular MPI/OpenMP hybrid parallel runs. To set up such runs, see HPC/Submitting and Managing Jobs/Advanced node selection.
Be careful how to allocate CPU cores on compute nodes.
- The number of MPI tasks running on a node is determined by options to mpirun.
- The number of threads that each MPI task runs with is usually determined by the environment variable
OMP_NUM_THREADS, which is 1 by default on Carbon. - The LAMMPS
package ompcommand has a mandatory argumentNthreadsto either overrideOMP_NUM_THREADS, or use it when set to*.
Usage
- Use the command
package omp Nthreads modenear the beginning of your LAMMPS control script. - Do one of the following:
- Append /omp to the style name (e.g. pair_style lj/cut/omp)
- Use the suffix omp command.
- On the command line, use the -suffix omp switch.
- In the job file or qsub command line, reserve entire nodes.
- Call the
lmp_openmpi(regular) binary.
Input file example
Examples:
package omp * force/neigh package omp 4 force
Job file example
- Single node:
#PBS -l nodes=1:ppn=8 … lmp_openmpi -suffix omp -in infile
- Multiple nodes:
# See HPC/Submitting and Managing Jobs/Advanced node selection#OpenMP/MPI hybrid for #PBS directives. … mpirun … \ lmp_openmpi -suffix omp -in infile
