Template:Catalog Header Modules
Introduction
This is the catalog for HPC applications on Carbon. Access to applications is managed using the Environment Modules package. An application may be referred to as a module, even though the underlying modulefile merely contains some metadata and setup items.
You, the user, must select ("load") the modules that you wish to use, possibly down to a specific version. An exception to this are a handful of basic modules that are pre-loaded when you log in.
You can access this catalog on Carbon itself, using the following commands to show all available modules, one-line summaries, and longer descriptions (usually with copyrights and links), respectively:
module avail [name] module whatis [name] module help name
- See also
- Module setup instructions
- The man page for the module command (
man module).
Table of Contents
- Index
- A compact list of packages, grouped by function.
- Summaries
- Package names, one-line summaries, and all available versions. The version shown in bold is the default (the version that is loaded when no specific version is given in the command line).
- Descriptions
- Long descriptions and package home URLs. Versions are listed separately if the descriptions differ.
- package names in blue lead to additional instructions.
- package names in red means no additional instructions are available. Inspect the package home directory after loading the module.
