HPC/Applications/atk/License troubleshooting on Windows
- Open a Windows command prompt.
- Inspect the current license setting.
C:\Users\OUadminMGS>echo %QUANTUM_LICENSE_PATH%
- You should get:
6200@localhost;6201@localhost
- If not log out, and log back in again, and repeat these steps from step 1 above.
- Run The following commands exactly as shown:
set LMX_EXTENDEDLOG=C:\Temp\lmx.log
set > %LMX_EXTENDEDLOG%
- You can select and Copy the string from here and Paste it into the Command Prompt window from the right-click context menu.
- Run this command, adapting it to the path you installed ATK under:
C:\"Program Files (x86)"\QuantumWise\atk-12.2.2\vnl\bin\vnl.exe
- It will take a few seconds for the command to start.
- Note: Do not start VNL by clicking on its icon in Explorer or its desktop shortcut.
- Move any VNL windows away from the command prompt window.
- Take a screenshot of your entire screen.
- Use Save Snip, Save As to produce an image file.
- Close VNL.
- In the Windows Explorer, navigate to the C:\Temp directory.
- Send by email the lmx.log file and the screenshot from step (5)
