HPC/Network Access/SSH Tunnel Setup and Use
The following sections document how to establish ssh tunneling on a Linux or MacOS X machine running OpenSSH. Numerous Windows solutions are available to provide the same functionality, but details vary considerably.
Manual setup
On your computer, run the following commands:
0. (Windows only) Start your X11 server if you have one.
1. Open a terminal window (such as Mac Terminal, Cygwin, PuTTY, or xterm).
2. Type:
ssh -v -N -L 33301:clogin:22 username@mega.cnm.anl.gov
3. Minimize that window - no further commands need be typed there.
4. Open another terminal window.
5. Type:
ssh -Y -p 33301 username@localhost
- Replace
usernameby the name of your Argonne account name. - Steps 4 and 5 can be repeated as often as desired.
- Replace
Do not type any commands at a prompt on mega.
Using an ssh config file
To simplify making connections from your computer, create or use an ssh configuration file there.
Config file contents
On your computer:
- Close any Carbon windows opened previously.
- Open a new terminal window.
- Linux: xterm
- Mac: Terminal.app
- Windows: a Cygwin window.
- Run the following multi-line command exactly as shown. (Copy & Paste all lines from the browser to your terminal).
cat > ~/.ssh/config << END_CONFIG
NoHostAuthenticationForLocalhost yes
Host mega
Hostname mega.cnm.anl.gov
User $USER
LocalForward 33301 clogin:22
LocalForward 33380 carbon:80
Host clogin
Hostname localhost
User $USER
Port 33301
ForwardX11 yes
ForwardX11Trusted yes
END_CONFIG
- Note for Cygwin users: To paste text into a Cygwin window, right-click with your mouse or use the Shift-Ins keyboard shortcut.
- Remove write permissions to the config file, its parent directory, and your home for anyone but you:
chmod go-rwx ~/.ssh ~/.ssh/config
chmod go-w ~
- Advanced users: See the ssh_config man page for syntax and options of the config file.
Connecting with a config file
With the config file in place, the commands in section #Manual setup above simplify to:
- 1. Once:
ssh -v -N mega
- 2. As often as needed:
ssh clogin
Test remote graphics using X11
- In a terminal connected to a Carbon login node, run the command:
echo $DISPLAY
- You should get something like:
localhost:17.0
- The numeric part will vary.
- Start a simple X11 program:
xload
- You should see a small window pop up on your screen.
- Close the window using its close button or press Ctrl-C in the terminal window.
- You can now use graphical applications on Carbon, for instance:
gnuplot
- This will start the gnuplot interpreter in a terminal.
- Create a sample plot – at the
gnuplot>prompt, type:
plot sin(x)
- To exit the program:
exit
File transfer
- There are many ways to transfer files through an ssh tunnel. However, you must always initiate the connection from the remote machine (your home computer), and either push files to Carbon or pull files from Carbon.
- With the above tunnel setup you cannot initiate a file transfer from Carbon or mega.
- Do not use mega as an intermediate. Files stored there wil be deleted.
Run the following example commands on your machine.
Copy a file to Carbon (push from outside)
scp -p foo clogin:remote/path/
Copy a whole directory to Carbon
Short of using tar or zip:
scp -rp local/path/ clogin:remote/path/
This method does not preserve symbolic links.
Copy a file from Carbon (pull from outside)
scp -p clogin:remote/path/foo local/path/ scp -p clogin:remote/path/foo .
Note the trailing "." in the last example to copy to your current directory.
- Reverse tunneling
The file copy operations above must all be initiated on the outside host. It is possible to set up tunnels to be able to initiate file operations on the inside. However, this is more complex and will be left as an exercise for advanced users. It involves setting up:
- agent forwarding
- a
.ssh/configfile on Carbon, and - specifying
-Rcommand line options orRemoteForwardconfig file directives when accessing clogin at the second stage.
Bonus – Intranet web access
Open the following links in a browser on your external workstation:
https://localhost:33343/cnm/HPC http://localhost:33380/
Advanced: Speeding up logins using ssh keys
Create a key
- Create an ssh key pair key if you do not already have one :
yourcomputer$ ssh-keygen -t rsa
The output will look like:
Generating public/private rsa key pair. Enter file in which to save the key (/Users/home_id/.ssh/id_rsa): Enter passphrase (empty for no passphrase): <-- Choose and enter a password. Enter same passphrase again: Your identification has been saved in /Users/home_id/.ssh/id_rsa. Your public key has been saved in /Users/home_id/.ssh/id_rsa.pub. The key fingerprint is: 42:c3:72:fb:4c:be:c6:80:81:bc:8b:73:d8:88:84:2e home_id@yourcomputer.local
- Inspect the .ssh directory on your computer. It should contain the following files:
$ ls -1 ~/.ssh config id_rsa id_rsa.pub known_hosts random_seed
- id_* are the just created key files.
Using an ssh-agent
On modern systems, the mere presence of private keys with their default names triggers handling through ssh-agent and brings up a passphrase dialog at the start of the desktop session or when a key is first requested for an outgoing connection. This is the case on MacOS X Leopard, where key management is largely automated through its general keychain concept; on Tiger, use SSHKeychain.app.
On older systems, you need to (a) set up the session to run under ssh agent and (b) request the passphrase upon login. Circumstances vary widely. Ask Google or your local admin for help. See also the page Getting started with SSH.
Place your public key on Carbon
To productively use your ssh key pair, you need to transfer the public half to Carbon.
Requirements:
- you have a public/private ssh key pair on your machine (called yourcomputer in this example).
- the public file on yourcomputer is named
~/.ssh/id_rsa.pubor~/.ssh/id_dsa.pub(either one will work). - the ssh host alias
megahas been set up on yourcomputer in~/.ssh/configand defines tunnels usingLocalForwarddeclarations. - the tunnel connection for mega is open, i.e., on yourcomputer,
ssh megaruns in another terminal. - the ssh alias
cloginhas been set up as described above. - an interactive session
ssh cloginsucceeds.
Then, to transfer your public key from yourcomputer to the Carbon login nodes, type:
cat ~/.ssh/id_rsa.pub | ssh clogin "umask 033; mkdir -p .ssh; cat >> .ssh/authorized_keys"
This command will append the contents of your ssh public key on yourcomputer to an authorized_keys file on Carbon. The command above is more reliable than cut&paste across interactive terminal sessions. If you created a dsa-type key, or chose your own name for the key pair, you'll have to cat the appropriate file instead. Remember to use the public part of the key, i.e. the file id_foo.pub.
Troubleshooting
If public keys do not work, use your password to gain access, then check the following:
- Permissions
- The directories and the
authorized_keysfile must, at the least, not be writable by anyone except yourself; other permissions are recommended to be restrictive as well:
login5$ ls -ld ~ ~/.ssh ~/.ssh/authorized_keys drwxr-xr-x 28 argonne_id users 4096 Feb 22 13:52 /home/argonne_id drwx------ 4 argonne_id argonne_id 4096 Feb 18 21:25 /home/argonne_id/.ssh -rw------- 1 argonne_id argonne_id 829 Oct 9 10:55 /home/argonne_id/.ssh/authorized_keys
- To change:
login5$ chmod go-w ~ login5$ chmod go-rwx ~/.ssh ~/.ssh/authorized_keys
- Corruption of
authorized_keysfile - The file should contain public keys in OpenSSH format, one per line, without additional line breaks. One way to check is:
yourcomputer$ cut -c1-50 ~/.ssh/authorized_keys ssh-rsa AAAAB3NzaC1yc2EAAAABIwAAAIEjdsfjJSAHkjh88y ssh-dss AAAAB3NzaC1kc3MAAACBAkkjsadfJFg7EFjDJhWEjk
The output should look similar to the sample above. Use your favorite text editor to join erroneously broken lines.
Note that there should not be anything like BEGIN RSA PRIVATE KEY, which would obviously indicate a private, rather than public key.
- Verify that an ssh-agent is running
To verify that an ssh-agent is running and visible to your shell, check for the presence of the environment variable SSH_AUTH_SOCK. To list the keys it has loaded, use ssh-add -l (lowercase "L"). Typical output is as follows:
yourcomputer$ echo $SSH_AUTH_SOCK /tmp/ssh-HCvZKt5478/agent.5478 yourcomputer$ ssh-add -l 1024 b9:65:98:c0:7c:25:da:b6:86:48:98:6b:2a:5a:9d:21 /Users/home_id/.ssh/id_rsa (RSA)
