HPC/Applications/vasp5
From CNM Wiki
VASP binaries
The vasp5 modules from version vasp5/5.2.12a-mkl-4 onwards contain several binaries built using different sets of preprocessor flags in the Makefile. Earlier modules only contain two binaries, vasp and vasp-gamma.
Additional binaries are provided for useful preprocessor flag combinations after applying patches from the group of Graeme Henkelman (UT Austin):
To verify the binaries available for a module, run, once the module has been loaded:
ls $VASP5_HOME/bin
Copy a sample job script from:
$VASP5_HOME/vasp.job
Choose a binary appropriate for your task and pass it to mpirun in the job script. There is no need for full path names.
Available binaries and their flags
MD capabilities Flags used Binary name
Official source Patched for VTST Patched for Bader-projected DOS
Conventional (none) vasp vasp-vtst vasp-baderdos
-DNGZhalf vasp-chargehalf vasp-vtst-chargehalf vasp-baderdos-chargehalf
-DwNGZhalf vasp-gamma vasp-vtst-gamma vasp-baderdos-gamma
-DwNGZhalf -DNGZhalf vasp-gamma-chargehalf vasp-vtst-gamma-chargehalf vasp-baderdos-gamma-chargehalf
Advanced
MD techniques
-Dtbdyn vasp-tbdyn not useful not useful
-Dtbdyn -DNGZhalf vasp-tbdyn-chargehalf
-Dtbdyn -DwNGZhalf vasp-tbdyn-gamma
-Dtbdyn -DwNGZhalf -DNGZhalf vasp-tbdyn-gamma-chargehalf
Common flags
-DIFC -DRPROMU_DGEMV  -DRACCMU_DGEMV -DCACHE_SIZE=16000  -DMPI -DMPI_BLOCK=8000
Explanantion of flags
From vasp.5.2/makefile.linux_pg
# possible options for CPP:
# NGXhalf             charge density   reduced in X direction
# wNGXhalf            gamma point only reduced in X direction
# avoidalloc          avoid ALLOCATE if possible
# IFC                 work around some IFC bugs
# CACHE_SIZE          1000 for PII,PIII, 5000 for Athlon, 8000 P4
# RPROMU_DGEMV        use DGEMV instead of DGEMM in RPRO (usually  faster)
# RACCMU_DGEMV        use DGEMV instead of DGEMM in RACC (faster on P4)
#  **** definitely use -DRACCMU_DGEMV if you use the mkl library
# additional options for CPP in parallel version (see also above):
# NGZhalf               charge density   reduced in Z direction
# wNGZhalf              gamma point only reduced in Z direction
# scaLAPACK             use scaLAPACK (usually slower on 100 Mbit Net)
vdW-DF functional
All binaries support the use of the vdW-DF functional of Langreth and Lundqvist et al.
No specific preparations are needed other than setting the INCAR flags as documented. The binaries will find the required precalculated kernel file vdw_kernel.bindat by means of the environment variable $VASP5_HOME which is set by the module. This is a Carbon-specific extension.
