HPC/Applications/vasp5
From CNM Wiki
< HPC‎ | Applications
Revision as of 19:00, February 17, 2012 by Stern (talk | contribs) (created)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
Binaries available
The vasp5 modules as of version vasp5/5.2.12a-mkl-4 contain several binaries, determined by CPP flags in the Makefile as shown.
To inspect the available binaries:
ls $VASP5_HOME/bin
vasp
(none)
vasp-chargehalf
-DNGZhalf
vasp-gamma
-DwNGZhalf
vasp-gamma-chargehalf
-DwNGZhalf -DNGZhalf
vasp-tbdyn
-Dtbdyn
vasp-tbdyn-chargehalf
-DNGZhalf -Dtbdyn
vasp-tbdyn-gamma
-DwNGZhalf -Dtbdyn
vasp-tbdyn-gamma-chargehalf
-DwNGZhalf -DNGZhalf -Dtbdyn
Common flags
-DIFC -DRPROMU_DGEMV  -DRACCMU_DGEMV -DCACHE_SIZE=16000  -DMPI -DMPI_BLOCK=8000
Explanantion
From vasp.5.2/makefile.linux_pg
# possible options for CPP:
# NGXhalf             charge density   reduced in X direction
# wNGXhalf            gamma point only reduced in X direction
# avoidalloc          avoid ALLOCATE if possible
# IFC                 work around some IFC bugs
# CACHE_SIZE          1000 for PII,PIII, 5000 for Athlon, 8000 P4
# RPROMU_DGEMV        use DGEMV instead of DGEMM in RPRO (usually  faster)
# RACCMU_DGEMV        use DGEMV instead of DGEMM in RACC (faster on P4)
#  **** definitely use -DRACCMU_DGEMV if you use the mkl library
# additional options for CPP in parallel version (see also above):
# NGZhalf               charge density   reduced in Z direction
# wNGZhalf              gamma point only reduced in Z direction
# scaLAPACK             use scaLAPACK (usually slower on 100 Mbit Net)
