HPC/Carbon Cluster - Development tools
< HPC
This is an overview of the compilers and MPI libraries available on Carbon. Each package name leads to its documentation.
- See also
- Module catalog.
Compilers
GNU family
Intel Software Development Products
As of 2011, we have the following tools under support within the Intel® Composer XE 2011 for Linux bundle.
- Intel C/C++
- Intel Fortran
- Math Kernel Library -- see also HPC/Software/Modules/mkl
- Integrated Performance Primitives Documentation (IPP)
- Threading Building Blocks Documentation (TBB)
- Debugger (idb)
Documentation is installed locally mainly under:
$ICC_HOME/Documentation
$ ls -F $ICC_HOME/Documentation/en_US Release_NotesC.pdf compiler_c/ documentation_f.htm getting_started_f.pdf lgpltext Release_NotesF.pdf compiler_f/ flicense idb/ mkl/ clicense documentation_c.htm getting_started_c.pdf ipp/ tbb/
No longer maintained on Carbon:
MPI
OpenMPI
This is the primary and recommended MPI version. It supports Ethernet and InfiniBand interconnect, with InfiniBand set as default by means of an OMPI_MCA_… environment variable.
Intel MPI
- See also
- HPC/Software/Modules/impi.
MPICH/MPICH2
- Not installed explicitly, but Intel-MPI is based on MPICH2 and provides an MPICH2 runtime environment for precompiled binaries.
